New Guy Needs Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > New Guy Needs Help
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 02-23-2014, 06:23 PM   #1
easternfisherma
Wk New Guy Needs Help
Good evening all, long story short, my sister took my brothers jeep after he passed away and is having trouble letting it go. I volunteered to help her take care of it over the last few years. Transfer case went so picked up a 242 to replace the 247 (no heavy duty just wanted her to be able to cruise around in 2wd and save a few bucks on gas the other 9 months out of the year when theres no snow. Installed the transfer case today not realizing i needed another rear drive shaft to fit the 242 i located one at a junk yard but cant get to it till tomorrow. I put everything back together and figured i could put the car in 4wd to move it off the ramps and out of the driveway. Put the car in 4wd and nothing, tried low and hi with no luck. Had my daughter assist while i peeked under the car and the front shaft is spinning. Im hoping i need the rear one installed to engage the front. Anyone have any ideas what this could be. After seeing the prices of a front diff i hope theres a simpler solution. Thanks for the help
easternfisherma is offline   Reply With Quote Quick reply to this message
Unread 02-23-2014, 09:20 PM   #2
shockracer
Did you move your linkage to the right spot on the bracket and are you using a selec-trac shift bezel to know where the selector belongs?
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
[COLOR="SeaGreen"] Colorado Jeep Club Member #262[/COLOR]
shockracer is offline   Reply With Quote Quick reply to this message
Unread 02-23-2014, 11:14 PM   #3
Johnyre
Just to let you know, a 242 won't save on gas as the front drive shaft is always engaged just not in the tcase. The front shaft spinning and not going anywhere means axle issue. could be broken pinion. Also check to see if it actually has axle shafts(not likely but possible after some of the stuff I've seen people do) Did it make any noise?
As I roll down the trail,I hope my traction will not fail.But if I spin & begin to slide,please dear lord protect my ride
http://www.facebook.com/pages/Cloud-9-Crawlers/129955857071110
http://fortcollinswheelers.com
Johnyre is offline   Reply With Quote Quick reply to this message
Unread 02-25-2014, 10:34 AM   #4
easternfisherma
Thanks guys -
I moved the linkage and added a home made shift indicator.
I hear you on the gas but should also cut down on wear and tear on the front end. Everything is where it should and no missing parts. Looks like a tough fix the front end. Is a pinion something I can handle in the driveway?
Unread 02-25-2014, 11:35 AM   #5
shockracer
Originally Posted by easternfisherma View Post
Thanks guys -
You moved the linkage and it works now, or it was already moved and doesn't work?
