New electrical gremlin! - JeepForum.com
post #1 of 7 Old 02-05-2014, 05:33 AM Thread Starter
bessyboy
Keep in mind that I was driving the car last evening with no problems. This morning I got into my car to warm it up and the battery was dead. I jumped it and after a few tries got it started. Ran fine checked volts and it was right around 14. After letting it warm up I got in and my ABS/Red Brake light came on. I got worried but it shut off after awhile. Then my speedometer started goin crazy like up and down. Drove it and almost died once pulled up to a light but it stuttered back to life. Pulled over checked battery connections and everything was tight. I decided to turn around and go back home and as soon as I shut it off I tried restarting it and it was dead. I'm leaing toward the battery being completely drained
-2001 WJ Limited, 4.7L V8, Thrush Glasspack muffler dumped before axle(no tailpipe), Spectra CAI,
Rusty's 2" BB
bessyboy is offline
post #2 of 7 Old 02-05-2014, 05:57 AM
Matrixxxx
2005 WK
your charge alt should provide power once your engine is running.
it could be bad earthing for it to affect so many pieces of equipment, id put a multimeter across the battery and see what it does when cranking, check electrolyte and do a discharge test on the battery. if the battery is out of warranty then replace if suspect.
check resistance between battery neg and chassis, or measure between pos and neg on your battery and pos on the battery and the chassis to see if there is any voltage difference, they should be the same or very close.
Matrixxxx is offline
post #3 of 7 Old 02-05-2014, 06:04 AM Thread Starter
bessyboy
Originally Posted by Matrixxxx
your charge alt should provide power once your engine is running. it could be bad earthing for it to affect so many pieces of equipment, id put a multimeter across the battery and see what it does when cranking, check electrolyte and do a discharge test on the battery. if the battery is out of warranty then replace if suspect. check resistance between battery neg and chassis, or measure between pos and neg on your battery and pos on the battery and the chassis to see if there is any voltage difference, they should be the same or very close.
So your saying that the battery is suspect? I'm going to take it to orielly after school and have it tested
Rusty's 2" BB
bessyboy is offline
post #4 of 7 Old 02-05-2014, 06:09 AM
Matrixxxx
2005 WK
well its a process of elimination, if the battery good then it could be an earthing problem. the battery's the easy bit to check.
post #5 of 7 Old 02-05-2014, 06:16 AM Thread Starter
bessyboy
I don't have any electrical equipment to test anything since I hate it. After reading many forums and such I'm having no doubts that it is the battery and becuase it was so dead the abs and brake light wernt getting enough power to function properly. I'll post later and see what happened
Rusty's 2" BB
bessyboy is offline
post #6 of 7 Old 02-05-2014, 01:42 PM Thread Starter
bessyboy
*Update* brought the old battery to oriellys and it tested bad. Upon other inspection I found some battery acid that was leaking out of the terminal area and such. So I bought a new one and it's running great
Rusty's 2" BB
bessyboy is offline
post #7 of 7 Old 02-05-2014, 02:01 PM
Krooser
I have seen owners spend hundreds of $$$ and hours upon hours trouble shooting persistent electrical snafu's only to find they had a bad battery. You did good...
Krooser is offline
