New cut key doesn't work - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > New cut key doesn't work
Unread 03-14-2014, 09:25 AM   #31
snorander
I took my one working key to the hardware store, they cut me a new key and programmed it for less than $75. Not as pretty as a factory key, but it works fine
snorander is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 09:46 AM   #32
rdkendrick
2003 WJ
Originally Posted by Capt_Howdy View Post
The problem with wording is the you can always bend and twist it to whatever you need. No you don't need ORIGINAL or DEALER PROGRAMMED keys to make your own using the Jeep. You just need two keys that have been enrolled in the Jeep separately. Who programmed them does not matter.
Now, you are twisting HIS words to fit YOUR argument. I understood what he meant. He said you needed two ORIGINAL keys, not one key a clone of the other, to create a third key.
Sent from my iPad using electrons
rdkendrick is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 12:24 PM   #33
jra8858
I just had a key cut and programmed and a fob programmed by a locksmith yesterday for 75 total. Included key, programming, and programming of the fob. I only had 1 key and no working fobs to begin with. He plugged his laptop tool in the obd port to program the key, and then used a different "RF" tool I believe is what he called it to program the fob. He even stated that even if I didn't have a single key he would still be able to cut and progam me a key as long as ignition cylinder was intact. Total time for the whole process was less than 10 minutes!
jra8858 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 12:46 PM   #34
Capt_Howdy
Even with two ORIGINAL keys, you still need a free programming slot in the immobilizer to create a third key.
Originally Posted by rdkendrick View Post
Now, you are twisting HIS words to fit YOUR argument. I understood what he meant. He said you needed , not one key a clone of the other, to create a third key.
Capt_Howdy is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 12:48 PM   #35
Capt_Howdy
What you have there is a clone key from the hardware store. Still works the same.
Unread 03-14-2014, 12:51 PM   #36
Capt_Howdy
You got a very good deal for $75. Did he or did you get the PIN code from the dealer to program the key?
Unread 03-14-2014, 12:56 PM   #37
snorander
Clone key, reprogramed key or whateever it is called, I could care less. It works That's all I care LOL
Unread 03-14-2014, 01:42 PM   #38
jra8858
All I did was call him, tell him what I needed, he told me he wason his way to a job almost around the corner from me. So I went there to meet him, 15 minutes later he arrived, cut my key, plugged in his laptop tool, and in less than 10 minutes I had a working key and fob! He was very professional, and courteous and would recommend him to anyone! But like I said he said even if I didn't have any key at all he still could cut and program a key for me onsite as long as the lock cylinder was intact. Here is a link to his website...
http://rochesterautokeyguy.com/
I am not in any way, shape, or form affiliated with this business, Im just a very satisfied customer!
Unread 03-14-2014, 02:18 PM   #39
Capt_Howdy
No key situations are common place. The most common way to cut a new key without having keys is to cut by code. On a Jeep their are a few ways of doing this, you can get the key code from the dealer by having them look up your VIN or you can decode the door locks to get the key code. I might make a video on this one day.
Unread 03-14-2014, 06:52 PM   #40
rdkendrick
2003 WJ
No one said you didn't.
Unread 03-14-2014, 07:31 PM   #41
jra8858
Maybe in your experience, but No you not correct in my situation there was no code, and no involvement with a dealer. I was specifically told all he needs is access to the lock cylinder. Im pretty sure a certified locksmith like him isn't relying on a dealers help to make a living. I posted the link with his website, feel free to contact him yourself. All he would need without any key is access to your lock cylinder, access to your obd port, and a payment of $65.
Unread 03-14-2014, 09:46 PM   #42
Capt_Howdy
You would be surprised how many certified locksmiths like him have to rely on a dealers for the PIN codes. The software used to dump the PIN code from the DLC is relatively new and not cheap and it does not work with all Chrysler/Jeep models. On 99-00 WJ's the immobilizer has to be removed and opened to extract the PIN code. Having done it via the DLC your Jeep must be 01-04.
Unread 03-15-2014, 08:41 AM   #43
grussell
Right now WJ #1 only has 1 key and it broke off at the head last weekend. I took it to ACE Hardware and they made a new key and cloned the code and it works! The cost was $79 plus tax. I had a spare door key made just for a lock out. When I get my builds behind me deal with the keys. I have been to 2 Jeep dealers and both said they will not program an ebay key.
2001 GC Laredo 4.0 4x4 - Black l 2001 GC Laredo 4.0 4x4 - Silver
grussell is offline   Reply With Quote Quick reply to this message
Unread 03-15-2014, 10:04 AM   #44
grussell
Right now WJ #1 only has 1 key and it broke off had the head. I took it to ACE Hardware and they made a new key and cloned the code and it works! The cost was $79 plus tax. I had a spare door key made just for a lock out. When I get my builds behind me deal with the keys.
Unread 03-16-2014, 10:44 AM   #45
Capt_Howdy
The only thing that I don't like about cloned keys is the fact that they use a battery. If the battery dies in the key you ain't going anywhere.
