New cut key doesn't work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > New cut key doesn't work
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 03-05-2014, 05:14 PM   #1
SirSilvia
Wj New cut key doesn't work
I have 2002 Jeep Grand Cherokee Limited and just had a key cut. Unfortunately the Jeep won't stay on and the key light blinks. I didn't think the WJ I have has a transponder does it?
2002 Jeep Grand Cherokee Limited V8
SirSilvia is offline   Reply With Quote Quick reply to this message
Unread 03-05-2014, 05:18 PM   #2
Stimmel
Yes it does
Stimmel is offline   Reply With Quote Quick reply to this message
Unread 03-05-2014, 05:21 PM   #3
soonerdg
2003 WJ
Yep it's got a SKIM. You gotta get they key from the dealer and have i coded to your car. And it isn't cheap!
soonerdg is offline   Reply With Quote Quick reply to this message
Unread 03-05-2014, 05:23 PM   #4
irzyxel
$45 here
2004 Overland stock with 103,000 miles
irzyxel is offline   Reply With Quote Quick reply to this message
Unread 03-05-2014, 05:26 PM   #5
soonerdg
2003 WJ
Originally Posted by irzyxel View Post
$45 here
Really? To buy the key AND have it coded? It's closer to $300 here.
Unread 03-05-2014, 05:48 PM   #6
ezflip
ezflip's Avatar
They key itself is expensive from the dealership. Buy one on ebay and take it to them to program. Some dealerships even do it for free as a courtesy for loyal customers. Others charge around 30 minutes of labor. Its literally a 2 minute job for them to do.
And OP: Every WJ sold in the US has SKIS.
~James
2002 Overland - 4.7 HO, "Select-Drive", 4" RC long arms, TAG front winch bumper, 32" BFG KM's, 3" exhaust, Magnaflow hi-flow cat, Flowmaster 50 series
Build Thread
ezflip is offline   Reply With Quote Quick reply to this message
Unread 03-05-2014, 05:50 PM   #7
bradywgn71
bradywgn71's Avatar
If you have two working keys, you can program a third one yourself. Otherwise, dealer or possibly a locksmith.
http://www.wjjeeps.com/sentry.htm
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline   Reply With Quote Quick reply to this message
Unread 03-06-2014, 09:06 AM   #8
ChrisHager
ChrisHager's Avatar
Having the dealer do it is the better option. The key code will be unique. Though I've heard some locksmiths are doing this now, typically they just copy the code from the existing key.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 03-06-2014, 09:37 AM   #9
Capt_Howdy
The key code comes with the PIN code, so cutting new keys from code is really not even an issue.
Capt_Howdy is offline   Reply With Quote Quick reply to this message
Unread 03-06-2014, 09:42 AM   #10
ChrisHager
ChrisHager's Avatar
I'm talking about the code programmed into the key that pairs with the SKIM in order to verify the key is correct...
Originally Posted by http://wjjeeps.com/sentry.htm
In situations where only one key is available, keys must be programmed by the dealer via the Secured Access Method. The Secured Access method applies to all vehicles. This method requires the use of a DRBIIIt scan tool and will also require that you have access to the unique four-digit PIN code that was assigned to the original SKIM. The PIN code must be used to enter the Secured Access Mode in the SKIM. This PIN number may be obtained from the vehicle owner, from the original vehicle invoice, or from the DaimlerChrysler Customer Center. Refer to the appropriate diagnostic information for the proper Secured Access method programming procedures.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 03-06-2014, 12:09 PM   #11
georged
Check with WallMart. They might be able to copy the code if you have one original key.
georged is offline   Reply With Quote Quick reply to this message
Unread 03-06-2014, 12:27 PM   #12
ezflip
ezflip's Avatar
There is nothing to copy. They cannot just copy a code from an existing key. The PIN they are referring to is more of a password to access the skim.
The keys have RFid chips in them and are hard coded with a unique id like a serial number. No two keys have the same id...ever. You have to program the module in the jeep to recognize the unique id in the key. Again, the module in the jeep is programmed, NOT the key. With two working keys, you don't need the PIN or DRB, using the existing keys you can access the skim and then program it recognize the new key. But if you only have one key, the only way to do this is with a DRB. It is rare that a run of the mill locksmith with have a DRB, but they are out there.
But again, you cannot just "copy" the RFid from one key to another. You have to tell the module in the jeep which RFid's to accept.
Sent from inside my dinosoar head.
~James
Build Thread
Unread 03-06-2014, 01:03 PM   #13
Capt_Howdy
You can copy one key to another, this is called key cloning. No DRB or PIN code needed to clone, just one good working key. This is what most box stores do that offer transponder key sales. In fact this is the only way to make a working key without the need to access the car. Dealers wont clone keys, they are not equipped to clone keys.
Unread 03-06-2014, 01:28 PM   #14
alfaitalia
CRD Pilot!
alfaitalia's Avatar
Not true. There are a few US owners of early 99 models on here with chip free keys. I did not believe them when they first said until they proved it! The keys even look slightly different. They usually post to say so on threads like this!
Sent from the Dark Side using only the Force.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline   Reply With Quote Quick reply to this message
Unread 03-06-2014, 01:48 PM   #15
Capt_Howdy
I have seen early 99 models in Canada without SKIM. The wiring and plug for the SKIM is there just no module is installed. The owners of these models have a hell of a time finding ECU replacements since there is no way to tell between a SKIM or no SKIM ECU.
