Neutral safety switch 3 wire colors/or bypass - JeepForum.com
post #1 of 5 Old 06-01-2011, 08:18 PM Thread Starter
TheGeek
Wj Neutral safety switch 3 wire colors/or bypass
Recently I had a Park neutral switch going bad code on my 2001 WJ Grand Cherokee 4.0 I bought the new switch, but when I went to change it out, the 3 wires on the connector are all exposed and frayed/melted. So I went to my local Jeep dealership to get a new CONNECTOR, but they can't get them. So I went to my local junkyard... no WJ's. I cut the end of the connector off, tried to splice in some fresh wires and heatshrunk the exposed wires. Upon rehook up, it will not start. I don't know if I mixed up the order of the three wires or what. Kinda hard to tell the exact colors of the wires (being under the car and covered in grease), but I think they are GREEN, YELLOW striped with unknown color, and TAN. Am I close here? I can't find any wiring diagram for it in the back of the Haynes manual. I'm guessing when I reconnected it all, that it's either wrong, or the connector is so frayed that it's not getting any juice. I've read about bypassing it by grounding the center wire, but I don't know which one was the center wire now. If I do bypass it, will I have problems with my backup lights? Will my check engine light turn off finally?
I noticed that when you snap the connector back on, there is no catch/stop so is it possible to put it on backwards/upside down?
I need help here. This is driving me crazy. Anyone got a diagram with color codes or advice about bypassing it?
TheGeek is offline
post #2 of 5 Old 04-03-2012, 07:59 PM
longdecember
exact same problem. replaced frayed wires after getting the code and now it wont fire. Any ideas anyone??
she's a real grand Rio Grande: 4" RE, 35" pro comp's, trail damage
longdecember is offline
post #3 of 5 Old 05-01-2012, 01:39 AM
Dasko
Did you have any luck I'm doing that tomorrow and could really use a reference. Thanks
2005 Grand Cherokee Limited - 5.7 HEMI - QDII - 2" Rough Country BB - AFE Stage 2 CAI - Monkey Navigated - Rear Shackle
2001 WJ- SOLD
Originally Posted by mrJ
It's a Jeep, it's not supposed to work right all the time.
Dasko is offline
post #4 of 5 Old 05-01-2012, 07:44 AM
rm2001wj
rm2001wj's Avatar
This image is from the 01 FSM. In case you need a translation: VT/BK = violet/black, BR/YL - brown/yellow, and WT/TN = white/tan.
rm2001wj is offline
post #5 of 5 Old 05-04-2012, 02:00 PM
97CherokeeSport
Awesome, this thread isnt 2 years old. I have a 1997 Grand Cherokee 4.0l. I did a transmission swap to a ax15. Standards dont have a NSS. My 42RE has the 3-pin/3-wire NSS that goes to the back up lights as well. Which wire do I ground to start and have my Jeep run? The Middle one, as per your diagram?
Thanks in advance!
97CherokeeSport is offline
Replacing Neutral Safety Switch - a few questions 00RedWJ WJ Grand Cherokee Forum 2 05-14-2011 12:37 PM
Disabling Neutral Switch... Downside? zBeeble WJ Grand Cherokee Forum 6 04-03-2011 07:16 PM
Switch mounting location and how to wire through the dash? JeeperCreeper94 WJ Grand Cherokee Forum 11 01-20-2011 08:47 PM
2003 grand cherokee 42re- neutral safety switch sp3 WJ Grand Cherokee Forum 0 06-30-2010 01:51 PM
