Need transfer case explanation ASAP! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Need transfer case explanation ASAP!
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 06-23-2012, 08:36 PM   #1
warehimer34060
Question Need transfer case explanation ASAP!
I'm hearing a grinding noise right by the passenger side of the transfer case like the one in the video below so I am thinking it was the chain. I pulled the case and found out that the chain has tension and is not scrapping the bottom. While looking it over and cleaning out the internal components I spun the input planetary gear(the one closest to the transmission) and it spins ok but it seems to make a slight grinding noise and has a slight wobble as it spins around. Since I have never taken these things apart I am not sure if this is normal gear noise, the gears appear ok from the outside but I haven't taken apart the input bearing and planetary gear assembly. Any ideas? Thanks
warehimer34060 is offline   Reply With Quote
Unread 06-24-2012, 12:22 AM   #2
ezflip
most like the the input shaft bearing. Fairly easy to replace, especially since you already have the case out.
2002 Overland - 4.7 HO, "Select-Drive", 4" RC long arms, TAG front winch bumper, 32" BFG KM's
Build Thread KCCO
ezflip is offline   Reply With Quote
Unread 06-24-2012, 09:31 AM   #3
warehimer34060
How loose should the planetary gear be because I took it out and spun it and it was wobbling and making the noise by itself. I mean, I think those gears are hydraulic so when the fluid expands then so does it.
Unread 06-25-2012, 12:15 AM   #4
ratmonkey
R.I.P.
ratmonkey's Avatar
They're in s fluid bath, no hydraulic pressure to the input planetary.
ratmonkey is offline   Reply With Quote
Unread 06-26-2012, 12:22 PM   #5
warehimer34060
So there shouldn't be any play in the gear?
Unread 06-26-2012, 11:17 PM   #6
ratmonkey
R.I.P.
ratmonkey's Avatar
Pull the planetary assembly, if there's play in any of the gears you need a new case. I don't think I've ever seen a planetary set for sale alone.
Unread 06-26-2012, 11:31 PM   #7
warehimer34060
Yeah there was play in most of the gears. My WJ does have 183k miles on it so it makes sense... I ordered a case from a junkyard that was in perfect working condition. Hope this will solve my problem.
