Need Trans help please!!! - Page 2 - JeepForum.com
post #16 of 26 Old 05-23-2011, 07:11 PM
sixmikey9
2003 WJ
I'm having about the same exact problem with my 42re. I also did the governor sensor and solenoid replacing and band adjusting. Nothing seems to work. I really don't want to pull the transmission. I'll post back here if I come up with something.
Sent from my HTC Evo 4g using the JeepForum ap.
sixmikey9 is offline
post #17 of 26 Old 05-24-2011, 08:35 AM
DICESARE
I saw on ebay there was a kit of all the sensors and solenoid, I think it was four. I'm going to buy them and throw them in and see what it will do... I guess this is my last step before I am forced to put it in the show and get rebuilt... :-(
DICESARE is offline
post #18 of 26 Old 05-24-2011, 07:42 PM
CarlJH
2003 WJ
Have looked at the haynes book and it says there is a throttle cable going to the transmission from the throttle body on the engine that syncs the two so one doesn't lag behind the other it is adjusted at the engine end if yours has this see if there's any slack in the cables
CarlJH is offline
post #19 of 26 Old 06-01-2011, 06:51 AM
DICESARE
I checked the cable and it was perfect no play at all... I am just going to change all 4 sensors new wik filter (since I have the 42re or rh there is only the one filter right?) and attempt to adjust the bands. Can anyone give advise on adjusting the bands. I have never had to do it before and the Haynes book says tighten to 72 in-lbs then back off 3 5/8th turn... I know what it's saying but is it correct?
DICESARE is offline
post #20 of 26 Old 06-01-2011, 09:26 AM Thread Starter
RyanMcholan
Ok fellas, I just found out after chagning all sensors, adj bands, and making sure kick down cable is adj right. Then if the tranny is still acting up then you need a new transmission. These can't even be rebuilt, SO I'V BEEN TOLD. Once the case gets too much whear it will not hold fluid pressure, which in turn will cause the trans to stick in gear and not shift. Like i said, i was told this by a local transmission shop. The case is alumnium and after so many miles something in the case wears down which in turn causing loss of internal fluid pressure. This sucks!!
RyanMcholan is offline
post #21 of 26 Old 06-01-2011, 09:31 AM
Thomahawk
Sorry to hear That. How many miles?
Buildthread
Thomahawk is offline
post #22 of 26 Old 06-02-2011, 11:16 AM Thread Starter
RyanMcholan
This on has 152K on it. guess thats not bad for an automatic. Although i'v got a friend who has a 97 ZJ with 324K still pulling.
post #23 of 26 Old 06-02-2011, 11:28 AM
Coolhand20th
umm which trans is it again? If it's a 42RE it can easily be rebuilt.
Coolhand20th is offline
post #24 of 26 Old 06-03-2011, 12:07 AM
DICESARE
I have a ZJ sitting out back with roughly 250k original trans and shifts perfect. I just got the WJ 2 months ago with 133k and its acting stupid. Go figure...
DICESARE is offline
post #25 of 26 Old 03-20-2012, 09:41 AM
NOLAwj
Wj Same problem
I am having the same problem with my wj 42re, I keep hearing about these bands that need to be adjusted. Have you done it and did it work?
NOLAwj is offline
post #26 of 26 Old 03-20-2012, 11:58 AM
jeepster250
TSB for 99 to 04 shifting problem rough or hard shift between 2 to 3 or 3 to 4 or 4 to 3.
jeepster250 is offline
Trans fluid? Thomahawk WJ Grand Cherokee Forum 26 04-18-2011 03:34 PM
New WJ. Trans issues? HELP! surfTJsnow WJ Grand Cherokee Forum 5 11-23-2010 07:02 PM
wj trans cooler TheBoss WJ Grand Cherokee Forum 14 07-16-2010 08:45 AM
WJ trans problems rugermack WJ Grand Cherokee Forum 4 06-14-2010 11:50 AM
01 WJ Trans not shifting compcrasher86 WJ Grand Cherokee Forum 10 06-11-2010 06:28 AM
