Need Trans help please!!! - JeepForum.com
post #1 of 26 Old 05-20-2011, 10:06 AM Thread Starter
RyanMcholan
02 Wj 4.0 with auto 2wd. Tranny still acting up. had fluid and filter changed, replaced throttle possioning sensor, replaced all shift solenoids in transmisson and still will not shift properally. sometimes if i start off easily it will shift out fine but if i give it throttle and it shifts down to passing gear(2nd) it will not shift to 3rd. I have to come to a compleat stop and even then it might hang in 2nd. Where is the speed sensor located?
ANY IDEAS??
RyanMcholan is offline
post #2 of 26 Old 05-21-2011, 06:47 AM
DICESARE
Having a similar problem. When driving cold it shifts from 1st to 2nd perfect but fron 2nd to 3rd what a pain. It just wants to rev to 4500, about 40 mph and just hands there for a little then a hard shift. Or when it gets to 40-45 mph just take foot of has let the rev drop and you hear it "zzzz" then shifts... Replaced trans fluid with atf+4 and replaced trans filter still same problem. When it's hot 30+ min of driving it shifts perfect 15ish mph, 25ish mph, 35ish mph, ect
DICESARE is offline
post #3 of 26 Old 05-21-2011, 06:50 AM Thread Starter
RyanMcholan
OK just replaced the speed sensor and still not fixed. Any body out their know anything about the transmission control mod??
post #4 of 26 Old 05-21-2011, 07:07 AM
RedlegWJ
There IS suppose to be some delay until it reaches operating temp. to protect the tranny. You can confirm in the owners manual. Might check for some codes to be sure it isn't acting more severe.
RedlegWJ is offline
post #5 of 26 Old 05-21-2011, 07:22 AM
DICESARE
Even if let idle for 10 min before driving off still stays in 2nd like I said until it gets HOT.
DICESARE is offline
post #6 of 26 Old 05-21-2011, 08:46 AM
RedlegWJ
WHen in park, there is no circulation occurring in the transmission, only while in gear or nuetral.
RedlegWJ is offline
post #7 of 26 Old 05-21-2011, 09:04 AM
CarlJH
2003 WJ
if you have been changing the sensors in the tranny the tcm needs to learn the new ones as they are all slightly different.
has it thrown any codes up for the tranny?
CarlJH is offline
post #8 of 26 Old 05-21-2011, 09:41 AM
04WJGuy
04WJGuy's Avatar
If your running the 42RE transmission have you adjusted the front and rear bands?
Canadian Jeeps Member #35
Black Jeep Society Member #325
The Galloping Green Llamas Member #37
04WJGuy is offline
post #9 of 26 Old 05-21-2011, 11:15 AM Thread Starter
RyanMcholan
Band adjustment??
I haven't had a code yet. even when it first started no codes came out and even after changing all these sensors their are no codes or a check engine light. How do you adjust the bands?
post #10 of 26 Old 05-21-2011, 09:52 PM
DICESARE
Never replaced any sensors here. Which ones would be recommended to change?
DICESARE is offline
post #11 of 26 Old 05-22-2011, 11:01 AM Thread Starter
RyanMcholan
sensors
Well i do some mechnic work on the side and have even rebuilt several GM automatic transmissions. I usually check the throttle possioning sensor, this sensor tells the trans when to shift according to how much throttle is being used. On this jeep i'm working on I replaced the TPS and the speed sensor, which i was told on another forum that it was causing my problem, But it didn't fix problem. So now I'm baffled. Usually on a Gm tranny their no problem to fix, guess Jeeps are very diffrent.
post #12 of 26 Old 05-22-2011, 11:24 AM
DICESARE
Okay so since I was going to the parts store to get some sea foam I though well why not lets just gets the sensors now and do a basic tune up. First thing was first wanted to try and reset the ECU and PCM so I took off the neg. battery term. I put the new TPS on and also took off the the other two sensors and gave them a good cleaning with throttle body cleaner. While I had it all off and apart I gave the TB a good cleaning as well. Put the new TSS on; the old one had some silver trans matter on the tip of the sensor. Replaced the air filter, spark plugs, and new boots with the springs. She started right up and idled just as good as before, BUT still not wanting to shift to 3rd!!! So I drove her around for a little and jumped on the interstate and opened her up WOT till 80ish. Got off the interstate and she shifted in all gears better then before when hot. I really don't know if the problem is still there or not since it is hot but will repost with an update when i take off for work tonight. When I take off for work I will do a video from the second I start it up so everyone can see RPM vs. MPH in regards to the shift points being cold. Then when I get to work it should be warm enough to see how it shifts correctly.
I really hope this works... :-)
Thanks in advance for all the help.
DICESARE is offline
post #13 of 26 Old 05-22-2011, 04:13 PM
Buddha_Kip
Buddha_Kip's Avatar
when you changed the fluid and filter, did you change out the cooler return filter as well? There's actually a TSB on this part failing (21-015-05). Check here for full info and part numbers for new part - http://dodgeram.info/tsb/2005/21-015-05.htm
2000 WJ Limited - 2.5" Rusty's springs WAAG 1-piece front brush guard custom built WAAG nerf bars PIAA 580 lighting Custom Paint One-off Aluminum Treadplate Door Entry Guards & Rear Bumper Step
1986.5 Porsche 928S - 18" Moda MD1 Autothority Chips Rear Muffler Bypass Short-Shift Kit
Grease Monkey & HNIC @ Clasik Auto
Buddha_Kip is offline
post #14 of 26 Old 05-23-2011, 01:49 AM
DICESARE
I see what your saying but I have a 42re. Didn't get the chance to take the vid because I woke up late and had to rush to work. (still not sifting right) I will do the vid on my drive home.
DICESARE is offline
post #15 of 26 Old 05-23-2011, 06:42 AM
DICESARE
Here is the link to that video I took in the morning...
DICESARE is offline
Trans fluid? Thomahawk WJ Grand Cherokee Forum 26 04-18-2011 03:34 PM
New WJ. Trans issues? HELP! surfTJsnow WJ Grand Cherokee Forum 5 11-23-2010 07:02 PM
wj trans cooler TheBoss WJ Grand Cherokee Forum 14 07-16-2010 08:45 AM
WJ trans problems rugermack WJ Grand Cherokee Forum 4 06-14-2010 11:50 AM
01 WJ Trans not shifting compcrasher86 WJ Grand Cherokee Forum 10 06-11-2010 06:28 AM
