Need some expert advice? - JeepForum.com
post #1 of 10 Old 08-03-2011, 09:03 PM Thread Starter
JHoffman369
Every once in a while when I'm driving and have my cruise set my jeep will kick down into a lower gear and then back to cruising gear...doesn't happen all of the time, maybe once a week, possibly even less than that? Any ideas on what it might be? I'm swapping out all of my plugs this weekend and will be changing my fuel filter in the coming weeks as well. Any help would be greatly appreciated.
JHoffman369 is offline
post #2 of 10 Old 08-04-2011, 07:00 PM Thread Starter
JHoffman369
bump
post #3 of 10 Old 08-04-2011, 07:09 PM
tbone1004
may be set at a weird speed where it's inbetween gears. Try upping the cruise a mile an hour or two and see if it does that. May be time for a tranny flush too
tbone1004 is offline
post #4 of 10 Old 08-05-2011, 08:41 PM Thread Starter
JHoffman369
That's what one of my buddies said too. I tried upping it 1, 2, even 5 mph before and that didn't do the trick.
post #5 of 10 Old 08-05-2011, 09:27 PM
4Tom
Check your vacuum hoses for leaks
WJ 2001 3.1TD
Tom
4Tom is offline
post #6 of 10 Old 08-05-2011, 09:34 PM
the88thpianoman
2003 WJ
TPS could be the culprit as well.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #7 of 10 Old 08-06-2011, 07:26 AM Thread Starter
JHoffman369
ok...not a "car guy" barely at all so I'll do my best to look around and see what/if I can find. Thanks for the input
post #8 of 10 Old 08-06-2011, 07:48 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Mine does this all the time. I have the 4.0 with bigger tires and 3:55 gears. I just do not have enough power to get up some inclines/hills and ti will downshift out of overdrive to get up the hill. Also could be fuel filter related.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #9 of 10 Old 08-06-2011, 07:59 AM
blazepsi
Changing my Fuel Filter Helped me with that Issue...
blazepsi is offline
post #10 of 10 Old 08-06-2011, 12:13 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Mine would occasionally do this as I started up hills with cruise on around 70mph, it would kick down to 2nd for a could seconds and then kick back to third. This was with the 4.7HO/545RFE, a LOT of gear, and driving at 4000-12000' altitude (mostly in the 6-8000 range). I found that if I hit the OD off button just as I hit the base of the hill it wouldn't do it nearly as much. Likewise, I also reduced it a lot by running premium fuel. Around sea level, I do fine on regular fuel/87 oct, but with the high load and high altitude it was really down on power.
If yours is doing it during low-load situations then there is something wrong. I would check the tranny fluid level, do the tune-up and consider replacing the TPS.
~Richard
billzcat1 is offline
Expert says it can't be done metalhead WJ Grand Cherokee Forum 13 05-30-2011 06:48 PM
4.0 engine expert needed wranglercory WJ Grand Cherokee Forum 7 04-21-2011 09:43 AM
Need Expert Jeep Mechanic in North New Jersey Chomot WJ Grand Cherokee Forum 6 12-18-2010 08:40 AM
need a 242 expert! skiebuster WJ Grand Cherokee Forum 5 10-25-2010 09:22 AM
Advice at 100 k wkgillingham WJ Grand Cherokee Forum 3 09-27-2010 12:10 PM
