Need O2 sensor advice? - JeepForum.com
post #1 of 15 Old 12-13-2013, 07:20 AM Thread Starter
Deadhorse
Have to get an inspection and check engine light is on, the diagnostic is showing both bank 1 and 2 sensors are failing. I can clear the system so the check engine light isn't on but in NYS would it pass inspection? if not are these what I need to buy and replace?
http://www.ebay.com/itm/Pack-O2-Oxyg...610534&vxp=mtr
Deadhorse is offline
post #2 of 15 Old 12-13-2013, 08:02 AM
ChrisHager
Administrator
ChrisHager's Avatar
Usually they can see that you've cleared the light...
If you need new O2 sensors, go through Kolak. Any off brand O2 will cause you issues almost immediately.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #3 of 15 Old 12-13-2013, 08:35 AM Thread Starter
Deadhorse
How many sensors are there on an 04 limited?
post #4 of 15 Old 12-13-2013, 08:37 AM
ChrisHager
Administrator
ChrisHager's Avatar
2 for Federal Emissions, 4 for California Emissions. Being that you said bank 1 and bank 2 are bad, I'd venture a guess that you have the California Emissions. I could be wrong as that's happened before (my wife can verify that) so I'd suggest crawling under and taking a look to see what you have before buying anything.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #5 of 15 Old 12-13-2013, 08:51 AM Thread Starter
Deadhorse
I think your wife is right Chris lol I've just been told that nothing after like 01 is cali emissions anymore but I appreciate the help.
post #6 of 15 Old 12-13-2013, 09:07 AM
ChrisHager
Administrator
ChrisHager's Avatar
On the WJ, any year (99-04) can have Cali emissions. Take a look at the part numbers in the chart at the bottom of this page: http://wjjeeps.com/oxygen.htm
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #7 of 15 Old 12-13-2013, 09:09 AM Thread Starter
Deadhorse
Crap I think you're right : (
post #8 of 15 Old 12-13-2013, 09:12 AM Thread Starter
Deadhorse
So the computer is showing bank 1 sensor 1 and bank 2 sensor 2, is there any way to tell which ones these are out of upstream front and back or downstream front and back?
post #9 of 15 Old 12-13-2013, 09:14 AM
ChrisHager
Administrator
ChrisHager's Avatar
Assuming you have Cali (you still need to check):
Referring to the picture above...
Bank 1 Sensor 1: 1/1
Bank 1 Sensor 2: 1/2
Bank 2 Sensor 1: 2/1
Bank 2 Sensor 2: 2/2
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #10 of 15 Old 12-13-2013, 09:24 AM
doityourselfMM
doityourselfMM's Avatar
Just to be sure, does your 04 have the 4.7?
Are the codes showing O2 Heater failures? WJ 4.0s are prone to throwing heater failure codes when the temps < 40F. Not sure about the 4.7. I hate to see you replace good sensors if the problem is software related. What codes are you actually getting?
doityourselfMM is offline
post #11 of 15 Old 12-13-2013, 09:46 AM Thread Starter
Deadhorse
I saw threads related to the incorrect heater codes and it is well below 40 here in upstate NY but the codes just pointed us to the O2 sensors, not sure what they were and the guy that did the reading has left.
post #12 of 15 Old 12-13-2013, 10:29 AM
Artie24
2008 WK
have the same codes popping up on mine whenever it gets really cold, usually they go away as soon as the it gets up above 40*
Artie24 is offline
post #13 of 15 Old 12-13-2013, 10:51 AM Thread Starter
Deadhorse
Will a mechanic have anyway of diagnosing the codes to seeing if it actually is the sensors or the incorrect codes because of the cold?
post #14 of 15 Old 12-13-2013, 11:23 AM
1025wj
You can clear the codes but often you need to drive a specific amount of miles before your vehicle is able to be tested....after you clear the code. I ran into a similar issue, and made the mistake of replacing my sensors with Bosch...however i found out that the WJ's are very picky about what sensors you put in. The bosch were junk and had to change them after a month, i ended up with going NTK from Advance Auto which seem to be working fine after a year, the codes went away. Mopar sensors were expensive from the dealer and had to be ordered.
1025wj is offline
post #15 of 15 Old 12-16-2013, 01:56 AM
link375
link375 is offline
