Need a little help - JeepForum.com
post #1 of 4 Old 07-18-2013, 06:19 PM Thread Starter
wjtank21
Need a little help
So my t case is crap so I found a couple for sale I had a 247 in it don't remember the spline count input and output shaft the out put is easy to find out! Any one know the spline count on a 99 wj with. 4.7? Any help on any one knowing?
wjtank21 is offline
post #2 of 4 Old 07-18-2013, 11:45 PM
cykaaro
Does this help? Should be for a '99 NV247
.................................................. .............. NV 247...............NV 242j
Input Shaft Length.......................................2.4125"...............2.4125"
Input Shaft Spline........................................23...........................23
Rear Output Shaft Diameter................ ........1.1750"................1.3750"
Rear Output Shaft Spline.............................27............................32
Front Output Shaft Yoke..............................CV Style.............U-Joint Style
Overall Length of Transfer
Mounting Flange to End of Output Shaft........17".........................19"
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #3 of 4 Old 07-18-2013, 11:57 PM Thread Starter
wjtank21
Yes it does but not In The way I was hoping unless you can tell me the numbed that don't match up don't matter
wjtank21 is offline
post #4 of 4 Old 07-19-2013, 01:50 AM
cykaaro
The one column "NV247" are the specs for a '99WJ 4.7 Quadrive II, the "NV242j" are from an '02WJ V8. The chart is in reference to someone who was swapping in the 242j into their '99. The differences shown are the differences between the two t-cases.
cykaaro is offline
