Need Help Really Confused - JeepForum.com
post #1 of 14 Old 06-20-2010, 02:47 PM Thread Starter
ljhopp
99 wj 4.7
I keep getting a check engine light on for p1391, I have replaced both the cam and crank sensors. I have even replaced the tps to see if that would work but the jeep still puts out a check engine light. Along with the check engine light on the jeep is missing or studdering when I floor it. I am really confused to what could be causing the jeep to have this problem. The jeep will also sometimes not do it, so I floor it again and then it will do it again.
I also have just replaced this engine and I don't no how long the jeep was siting before I bought it so I don't know if the pcm has a problem, or if the pcm has the lastest flash. When I replaced different sensors the problem would happen at different rpm's when I floored it. I am lost to what the problem could be. Since every time I replace a sensor the jeep will run good then all of a sudden start having the problem again.
I am thinking maybe a bad pcm or a bad fuel filter but again I am just guessing.
Any help would be greatly appreciated.
ljhopp is offline
post #2 of 14 Old 06-20-2010, 03:15 PM
Wrangler11
Wrangler11's Avatar
Maybe clogged injectors since it only seems to happen when you floor it... Stop flooring it.
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #3 of 14 Old 06-20-2010, 03:41 PM Thread Starter
ljhopp
Would that cause a p1391 check engine light to come on.
ljhopp is offline
post #4 of 14 Old 06-20-2010, 06:04 PM Thread Starter
ljhopp
Here is a link to the engine.
YouTube - 99 jeep grand cherokee with p1391
ljhopp is offline
post #5 of 14 Old 06-20-2010, 06:46 PM Thread Starter
ljhopp
Does anybody have an idea?
ljhopp is offline
post #6 of 14 Old 06-20-2010, 07:27 PM
narnwv
narnwv's Avatar
what's making the ticking noise when you're aiming at the engine bay? where is that coming from?
narnwv is offline
post #7 of 14 Old 06-20-2010, 07:30 PM Thread Starter
ljhopp
The ac compressor is where it sounds like it coming from.
The engine I just got as a reman.
ljhopp is offline
post #8 of 14 Old 06-20-2010, 07:51 PM
narnwv
narnwv's Avatar
p1391 is "intermittent loss of cmp or ckp" I'd double check the connectors, make sure there's no corrosion, and follow the wires and make sure there's no kinks or sharp bends, etc.... I'd also check nearby grounds, pull them and sand off corrosion/rust.
narnwv is offline
post #9 of 14 Old 06-20-2010, 07:59 PM
Wrangler11
Wrangler11's Avatar
No idea, just a guess based on what is happening.
post #10 of 14 Old 06-20-2010, 09:07 PM Thread Starter
ljhopp
I have a haynes manual, so I have all the codes and what they mean. I am just really confused to what is causeing this. I double checked all the connectors and they look good. I think their is short somewhere in the wiring because it seems like the more I drive the jeep it seems to start having the problem soon on the rpm's. At first it wouldn't do it when in park and reving it, now it does it when in park and reving it so it seems to be getting worse. But as soon has it gets past the studder it takes off like nothing is wrong.
ljhopp is offline
post #11 of 14 Old 06-20-2010, 09:40 PM Thread Starter
ljhopp
Could the map sensor be causing this problem since it controls fuel delivery and lignition timing. Sounds like good guess to.
ljhopp is offline
post #12 of 14 Old 06-20-2010, 11:06 PM Thread Starter
ljhopp
Do you know where the wires that come from the sensor's go to? What pcm harness connector are they connected to, the one on the left side or middle or the right side.
Thanks
ljhopp is offline
post #13 of 14 Old 06-21-2010, 09:44 AM
narnwv
narnwv's Avatar
I am unsure which connector they are. It's not going to hurt anything to pull and clean the battery terminals, but while they're disconnected--pull and inspect the PCM connectors.
~Aaron
narnwv is offline
post #14 of 14 Old 06-21-2010, 09:18 PM Thread Starter
ljhopp
I did all that today and still nothing I even checked all the volts and grounds at the sensors and everything checked ok. I think I have a bad pcm that is causing the problem.
ljhopp is offline
Umm...I'm Confused stratons_yj ZJ Grand Cherokee Forum 17 01-22-2010 08:22 PM
How is this possible? im confused... lakailimited06 ZJ Grand Cherokee Forum 4 05-06-2008 11:27 PM
little confused 97 ZJ Steve ZJ Grand Cherokee Forum 11 02-03-2008 09:45 AM
I'm so confused! jcollins ZJ Grand Cherokee Forum 10 06-14-2007 07:01 AM
I am confused Kess ZJ Grand Cherokee Forum 3 11-06-2002 01:25 PM
