Need help with O2 sensors. Just a few questions. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Need help with O2 sensors. Just a few questions.
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 09-22-2014, 12:16 PM   #1
2003cherokee
2003 WJ
Mine is a 2003 with the 4.7 liter V8.
Just got the PO161 code when I had the idiot light checked.
Parts store said it is the downstream sensor.
Checked on Rock Auto for the sensors, but don't know which brand to get.
Mechanic that was in the store, overheard and told me to change both sensors. But I think I have all four (Cali emissions), so do I change them all?
And do I need to buy the removal tool to remove them and what does it look like or what size for my jeep?
2003cherokee is offline   Reply With Quote Quick reply to this message
Unread 09-22-2014, 09:16 PM   #2
Gerber54
If more than one is bad it should show a separate engine code. I got the Denso ones from rock auto and the check engine light was back on within a week. There are a few threads on here that suggest using Bosch or Mopar ones only. From what I have read the Bosch ones will last a few months before the light ends up back on.
As for tools they make a few different styles of O2 sensor wrenches. The sensors are on top of the exhaust and are really hard to get at with a regular wrench. Having a removal tool is going to save you a lot of frustration. I am pretty sure 7/8 is the standard but it could vary by manufacture so double check with whatever you end up purchasing.
Gerber54 is offline   Reply With Quote Quick reply to this message
Unread 09-22-2014, 09:39 PM   #3
HighOutput
2003 WJ
Denso sensors from RockAuto or buy Mopar.
They look like spark plugs sticking out of the exhaust, so follow the exhaust to see if you have 2 or 4. Then hit it with PB Blaster as they're usually on there pretty darn tight.
Click on the link for different types of sockets.
I use this one and hit the handle with a hammer and or attach a breaker bar. (I've hit it hard and hasn't broken yet)
P.S Whether you have 2 or 4 it won't hurt to the buy the whole set. Just change if it's throwing a code or just change them all out for experience and exploration purposes
But DO NOT cut the wires unless you are sure you have the correct part. They have different lengths of wire and the harness plugs are not all the same.
HighOutput is offline   Reply With Quote Quick reply to this message
Unread 09-22-2014, 09:44 PM   #4
ezflip
NEWS FLASH It snows in MI
ezflip's Avatar
Only buy Mopar. The universal replacements on Rock Auto are not guaranteed to meet the tight tolerances our Jeeps require.
~James
2002 Overland - 4.7 HO, "Select-Drive", 4" RC long arms, TAG front winch bumper, 32" BFG KM's, 3" exhaust, Magnaflow hi-flow cat, Flowmaster 50 series
Build Thread
ezflip is offline   Reply With Quote Quick reply to this message
Unread 09-22-2014, 09:58 PM   #5
HighOutput
2003 WJ
Rockauto parts for 02 sensor and 02 sensor removal socket
