Need help from HO owner, air intake swap. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Need help from HO owner, air intake swap.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi50" SINGLE ROW PANDEMIC LED Light bar FEATURES 4D Opt
Unread Yesterday, 03:23 PM   #1
Deviant6185
Ok so I swapped out the air intake manifold from a HO engine to my 2000 WJ I'm having one issue how do I connect this vacuum line I'm having rough idle and loss of cruise control I'm not sure if either has to do with this but I would like to check it off the possibilities list, picture attached it's the rear most vacuum line, on the top of the air intake manifold picture is attached how does this line attach? If possible pictures would be nice
Deviant6185 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 06:35 PM   #2
Jeeples
The Original 4DR Wrangler
Jeeples's Avatar
You need to tee it in to one of the other vacuum connections on the manifold. The older 4.7 manifolds had three vacuum ports, and the newer ones have only two, as you've found out. You can see the boss for the third connection straight ahead of your disconnected line. You can pull the manifold, drill the boss out, and thread in a barbed fitting as well.
And yes, the vacuum leak is related to your rough idle and lack of cruise control.
His: '00 WJ 4.7 Limited- Zone 4" SA lift, JKS BPE's
Hers: '03 WJ 4.7 Laredo- IRO 3", 245/75/16 Duratracs, Bilstein Shocks, JKS TB w/KOR Bushings, Rusty's A-Arm Spacer, CORE4x4 Adjustable Front Control Arms, Dynomax Exhaust, RB1 Nav -Coming Soon- Overland Rock Rails
Jeeples is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 06:53 PM   #3
Deviant6185
Oh ok so that last on isn't actually a hole it doesn't go all l the way through? As I've had a plastic air line kind of forcefully stuck in there but if that doesn't go all the way through then it was quite pointless... Than I guess I'll t into the one just forward of the line then...
Unread Yesterday, 08:32 PM   #4
Jeeples
Jeeples's Avatar
Yep.
Most folks just tee in to one of the other lines.
Unread Yesterday, 08:35 PM   #5
Deviant6185
Alright thanks for the info it's much appreciated.
Unread Yesterday, 09:19 PM   #6
Phatbudde
Jeeples
You state older engines have 3 vs. the 2 in newer ones. What year did this change? This is a pic of a 2002 HO (?) engine in my 2000, As you see it has 3....Just curious.
Phatbudde is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 11:15 PM   #7
Jeeples
Jeeples's Avatar
Originally Posted by Phatbudde View Post
Jeeples
I believe the change happened beginning in '03, at that time both the HO and non-HO shared the same intake manifold (including the '04 MY as well).
Of the three different WJ 4.7 intake manifolds, the '02 HO is supposed to have the highest flow rate, with the '03-'04 shared manifold falling right below it.
