Need help. Having starting problems. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Need help. Having starting problems.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFather's Day & Moving Day Sale!Lifetime Warranty On All Savvy/Currie Suspensions and John
Unread 05-01-2012, 03:09 PM   #1
JeepinInFl
Wj Need help. Having starting problems.
Have 2001 GC Laredo. 6cyl. When trying to start it now I can turn the key and it attempts to start. Takes 5-10 minutes of cranking before it catches. Replaced the fuel filter no help. Almost sounds like it is not getting gas.
I can hear the fuel pump kick on when the key is turned to the "on" position.
Going to check the plugs here shortly, I'm sure they need changed. Is one of the sensors bad ? I've read it could be the crankshaft sensor maybe ? I don't think it's the jets as I run a can of sea foam through about every 3 months.
I have no warning lights showing and no codes.
Thanks for any help. If more info is needed let me know.
______
KJ4PUF
JeepinInFl is offline   Reply With Quote
Unread 05-01-2012, 03:16 PM   #2
conkatonk
clean the injectors
ConkaTonk
04WJSE
conkatonk is offline   Reply With Quote
