Need to flush my 4.0 - JeepForum.com
post #1 of 8 Old 06-12-2013, 05:43 AM Thread Starter
rocky_lange
What brand of flush works best? Are there certain types or chemicals I need to avoid due to aluminum parts?
I am starting to see temps rising as of late and my girlfriend had it yesterday and overheated it blowing the crappy plastic radiator side tank. I'm going to replace the thermostat and probably give Griffin Rad a call.
rocky_lange is offline
post #2 of 8 Old 06-12-2013, 10:01 AM
Jrboarder27
I used amsoil engine flush on my 4.7, but its hard to get. I've got a Napa in town that sells amsoil products, but I still had to pay a lot for the shipping because they would only buy it in bulk
Jrboarder27 is offline
post #3 of 8 Old 06-12-2013, 11:18 AM
pinky2252s
Why doou think you need to flush the system? Just because it over heated doesn't mean there is a blockage. It was most likely a bad thermostat or something. I would replace the thermostat with the radiator and drain and refill all the coolant. It should be fine just doing that.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #4 of 8 Old 06-12-2013, 06:17 PM Thread Starter
rocky_lange
Because some idiot ran non HOAT coolant in it. It runs fine for a while, comes up to temp and levels off for a while, then it creaps up. If going slow or stopped it spikes.
post #5 of 8 Old 06-12-2013, 06:19 PM
pinky2252s
I would just "flush" it with water. Do a few drain and refills with just water until no coolant comes out any more. Used distilled water bought from the store.
Is it broken?
post #6 of 8 Old 06-12-2013, 06:46 PM
Jrboarder27
See, I wish I new you were talking about your cooling system
post #7 of 8 Old 06-12-2013, 07:03 PM
99WJ539918
Exactly, use distilled water. Mixing coolant types is bad. Replace your radiator and thermostat and might as well do the hoses, too. Fill, run, and drain it three to five times. Good luck.
Build Thread
99WJ539918 is offline
post #8 of 8 Old 06-12-2013, 08:06 PM
robby65
2007 XK Commander
I would do water pump too.
robby65 is offline
