Need advice: looking at a WJ to buy, trying to clarify issues - JeepForum.com
post #1 of 10 Old 11-06-2013, 12:09 PM Thread Starter
DirtDodd
Question Need advice: looking at a WJ to buy, trying to clarify issues
Hey Guys,
I'm looking at buying a buddy's WJ, but it has some issues that are concerning me bc I'm not sure what they indicate exactly, if anything, and I've read the buyer's guide (good stuff!), as well as a few other threads, so now turning to the experts for help! I'm new to the WJ, have only owned XJs and ZJs with the 4.0L.
It's a 1999 Limited 4.7L with Quadra-drive. 127,000 miles, runs great, shifts smooth, 4wd operating perfectly, and body and interior in great shape. Here are the issues:
Main one - lots of transmission fluid on the bottom of the pan of the transmission. Wet on the sides of the transmission, even above the pan gasket. What are the possible culprits? Overfilled? Bad pan gasket (hasn't been serviced as far as he knows)? Something going wrong internally and losing fluid out the vent? He was surprised by it, and the jeep sits in his garage almost all the time now, with no drip spots or puddles...?
Upper radiator hose very hard when at operating temperature. Very hot, and can't squeeze it in any at all it's so stiff. Softer and reasonably pliable once the engine has been shut off for several minutes. Also, while running, the radiator is very hot on the return side (upper hose), and just warm on the other side, as well as the lower hose on that side is much cooler. Engine is not overheating, stays right on the 210 indicator, but the temperature of the heater never reached "run you out of the car" hot...? Oh, and the coolant is the wrong color - GREEN! Been that way a little over a year... Is all this typical and I'm just reading into it too much? Almost seems like a clogged radiator to me, and I sure don't want to end up with overheating issues with this motor!
Cruise control not working, but neither is the horn button on the steering wheel? Could it be in the wiring or switches on the wheel, or is it most likely a vacuum leak somewhere?
And lastly, A/C not working. Low freon, bc he said he has had freon added to it and it worked before, plus I jumper wired the pressure switch and it engaged the compressor cluth and started running. I'm wondering where these systems typically leak, so I could start there? Didn't see any oily residue on top of the compressor where the lines attached, but didn't really have time to check anywhere else.
Thanks guys! I appreciate any and all input, that way I can cover all options and possibilities! And one thing is for sure after driving it, shoulda had a V8 a long time ago! lol
DirtDodd is offline
post #2 of 10 Old 11-06-2013, 12:41 PM
Vaporhead
Are you sure it's tranny fluid and not oil being blown back? Either way, if the fluid level is alright, I would just clean it up and change the pan gasket and filters.
I'll let others comment on that other stuff. Hard to type on my phone.
Sent from AutoGuide.com Free App
Vaporhead is offline
post #3 of 10 Old 11-06-2013, 12:57 PM Thread Starter
DirtDodd
Yeah, it's red, and covers the entire bottom of the transmission pan. The motor itself is pretty clean, with a slight wetness around the drain plug and the bottom of the bellhousing, which seems very typical to me for 14 year old vehicles. Thanks for the input!
DirtDodd is offline
post #4 of 10 Old 11-07-2013, 07:28 AM Thread Starter
DirtDodd
Update: He took the jeep to a transmission shop yesterday, and they took a look at it, and simply told him they couldn't find anything wrong with it, but couldn't suggest where they thought the fluid had come from, either,....? It has sat a lot over the last year, so could it simpy be the pan gasket seeping fluid?
DirtDodd is offline
post #5 of 10 Old 11-07-2013, 07:32 AM
djpeters
My trans pan was rusted so thin that fluid was seeping THROUGH it.....
2004 WJ Overland
djpeters is offline
post #6 of 10 Old 11-07-2013, 07:46 AM
eajones_01WJ
ive heard of 2 reason this might happen if it not coming from a seal/oring/gasket. if its coming down from the top of the transmission then it might be coming form the vent tube and if thats the case then i can think of two reasons. one is that the transmission was overfilled which it doesn't sound like thats the case. 2nd is there was/is a clog in the transmission forcing fluid out the vent.
eajones_01WJ is offline
post #7 of 10 Old 11-07-2013, 09:52 AM
rdkendrick
2003 WJ
Originally Posted by DirtDodd View Post
Hey Guys, I'm looking at buying a buddy's WJ, but it has some issues that are concerning me bc I'm not sure what they indicate exactly, if anything, and I've read the buyer's guide (good stuff!), as well as a few other threads, so now turning to the experts for help! I'm new to the WJ, have only owned XJs and ZJs with the 4.0L. It's a 1999 Limited 4.7L with Quadra-drive. 127,000 miles, runs great, shifts smooth, 4wd operating perfectly, and body and interior in great shape. Here are the issues: Main one - lots of transmission fluid on the bottom of the pan of the transmission. Wet on the sides of the transmission, even above the pan gasket. What are the possible culprits? Overfilled? Bad pan gasket (hasn't been serviced as far as he knows)? Something going wrong internally and losing fluid out the vent? He was surprised by it, and the jeep sits in his garage almost all the time now, with no drip spots or puddles...? Upper radiator hose very hard when at operating temperature. Very hot, and can't squeeze it in any at all it's so stiff. Softer and reasonably pliable once the engine has been shut off for several minutes. Also, while running, the radiator is very hot on the return side (upper hose), and just warm on the other side, as well as the lower hose on that side is much cooler. Engine is not overheating, stays right on the 210 indicator, but the temperature of the heater never reached "run you out of the car" hot...? Oh, and the coolant is the wrong color - GREEN! Been that way a little over a year... Is all this typical and I'm just reading into it too much? Almost seems like a clogged radiator to me, and I sure don't want to end up with overheating issues with this motor! Cruise control not working, but neither is the horn button on the steering wheel? Could it be in the wiring or switches on the wheel, or is it most likely a vacuum leak somewhere? And lastly, A/C not working. Low freon, bc he said he has had freon added to it and it worked before, plus I jumper wired the pressure switch and it engaged the compressor cluth and started running. I'm wondering where these systems typically leak, so I could start there? Didn't see any oily residue on top of the compressor where the lines attached, but didn't really have time to check anywhere else. Thanks guys! I appreciate any and all input, that way I can cover all options and possibilities! And one thing is for sure after driving it, shoulda had a V8 a long time ago! lol
Need to change the coolant and flush out your heater core. I sounds like it might be clogged up. Th green coolant can eat away at the water pump impeller blades, if left in there very long.
Cruise control, horn not working sounds like a bad clock-spring.
Sounds like your AC has a leak. Put dye in it and try to detect where it is leaking. Most likely condenser, or the AC lines.
Sent from my iPad using my fingers
rdkendrick is offline
post #8 of 10 Old 11-07-2013, 02:10 PM
Double E
Double E's Avatar
From WJjeeps.com:
The recommended mixture is 50/50 ethylene-glycol and water. Never use pure antifreeze.
Only Mopar Antifreeze Coolant, 5 Year/100,000 Mile Formula (glycol base coolant with corrosion inhibitors called HOAT) is recommended. This coolant offers the best engine cooling without corrosion when mixed with 50% distilled water. Note: Antifreeze mixture must always be at least 44%, all climates year round. Maximum protection (-90d) is provided with a 68% mixture protection.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #9 of 10 Old 11-07-2013, 11:39 PM
losttech
losttech's Avatar
The horn and cruise is almost certainly a clock spring as someone mentioned.
About a 60$ fix if you do it yourself.
losttech is offline
post #10 of 10 Old 11-08-2013, 02:02 PM Thread Starter
DirtDodd
Thanks for the input everyone! I've been reading as much as I can over at WJJeeps.com, so I think I have a pretty good handle on everything I should do to it if I buy it, so I'm formulating a game plan.
Thanks again! And I'll have to look into that clock spring to understand what yall are talking about, I haven't researched that yet.
DirtDodd is offline
