Navigation Radio Rec Amfm 6-Cd Mp3 Player Dvd - JeepForum.com
post #1 of 15 Old 08-16-2014, 08:43 PM Thread Starter
krotos
i have a 2000 jeep grand cherokee laredo and a friend gave me a chrysler navigation radio rec 6-cd np3 player dvd, i was wondering if i were to get the wiring harness for it could i install it into my jeep?
krotos is offline
post #2 of 15 Old 08-17-2014, 11:23 AM Thread Starter
krotos
so no one?
krotos is offline
post #3 of 15 Old 08-17-2014, 01:23 PM
SirSilvia
ebay may be the best but what's the model on the sticker? because there's like a few dozen different types
2002 Jeep Grand Cherokee Limited V8
SirSilvia is offline
post #4 of 15 Old 08-17-2014, 05:01 PM Thread Starter
krotos
my question was would it fit and if i made the wiring kit myself, the p/n is P56038646AL.
krotos is offline
post #5 of 15 Old 08-18-2014, 11:26 PM
SirSilvia
They do have double din mounts and bezel http://www.ebay.com/itm/Double-Din-R...006969&vxp=mtr and comparing the connectors of the stock unit RBP and the one you have.
they match up, so looks like that kit ^ will do it for you
post #6 of 15 Old 08-18-2014, 11:29 PM
SirSilvia
If you have a CD changer, looks like it would work for you too and the antenna port is the same. all plug-n-play
post #7 of 15 Old 08-19-2014, 05:22 AM
pdpunome
rec is that not out of a 05 and newer chryslers? Those would be canbus and not work in pre 04's. What is the part number on the radio?
2000 4.0 Selec Trac
pdpunome is offline
post #8 of 15 Old 08-19-2014, 07:18 AM Thread Starter
krotos
ok i am guessing SirSilvia is kinda blind and pdpunome is the same, in my third post i listed the P/N and told. i am not looking for a double din mounting kit, SirSilvia read closer to the screen fellow i am asking if i made the wiring harness if it would work not if it will fit. here is the p/n again for those who can't read good P56038646AL.
krotos is offline
post #9 of 15 Old 08-19-2014, 10:59 AM
SirSilvia
I did read, but google lied to me when I put in the number.
Still looking at the standard head unit that came with the WJ's and the one you have P56038646AL it still has the standard antenna jack, the C1 (22 pin connection) and the CD Changer C2 (10 pin connection) in addition to the SAT antenna port as well.
The original head unit google pulled up looked like a double din, sorry about that. The one you have looks a lot bigger. I've never seen it done but doesn't mean it's not going to fit. there's nothing that I know of above the head unit other than the top of the dash.
post #10 of 15 Old 08-19-2014, 11:26 AM Thread Starter
krotos
ok i am sorry for the lashing, i do know i would have to modify the dash for it to fit. my main question was if i wired up a harness will the factory infinity amp going to allow it to work or do i need to buy a kit to get it to work.
krotos is offline
post #11 of 15 Old 08-19-2014, 11:41 AM
SirSilvia
It looks like pdpunome would know the specifics of it might not work. Other than the physical connections and fitment.
post #12 of 15 Old 08-19-2014, 11:58 AM
pdpunome
I can read thanks maybe next time you would like help dont be rude.
This will not work it is canbus for 05 and up chryslers.
Goodluck
2000 4.0 Selec Trac
pdpunome is offline
post #13 of 15 Old 08-19-2014, 02:07 PM Thread Starter
krotos
wasn't being rude just trueful, i did post the p/n of the unit in post #4.
krotos is offline
post #14 of 15 Old 08-19-2014, 02:09 PM
pdpunome
no rude, thanks and if you want help dont be like this and yes you did write the part number but nothing to lead anyone to know what you were referencing in that exact post.
again good luck.
2000 4.0 Selec Trac
pdpunome is offline
post #15 of 15 Old 08-19-2014, 03:10 PM
rdkendrick
2003 WJ
AFAIK, it won't work with the steering wheel controls, because of CANBUS. Not sure if it will work with the Infinity amp, or not.
Connectors DO look the same. All I can say is try it. What have you to lose, but time?
Sent from my iPad using Electrons
rdkendrick is offline
