Mystery coolant leak 2002 I6 4.6 stroker - Page 2 - JeepForum.com
post #16 of 32 Old 09-02-2013, 05:39 AM Thread Starter
scross1220
2012 WK
Originally Posted by Upside View Post
I just installed a new radiator and hoses 3000 miles ago due to a cracked radiator. My low coolant annunciation came on last week so I added a quart of water to the reservoir. I think the system just burped some air but I have the same situation you describe. No signs of coolant loss but I had a drop in quantity somehow.
Lets see if yours continues to go down. I made the change 3500 miles ago.
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[o]llllll[o]
_.(o)_)__(o)_)--o-)_)
If you're not fixing it, you're not driving a Jeep.
scross1220 is offline
post #17 of 32 Old 09-02-2013, 12:29 PM
WJ2000
Hey just wanted to say , I designed a brand new after market Radiator just
for our 4.0 motors, Its 3 quarts larger an x2 times the cooling capacity of that little stock unit . And it fits in the same space with no modifications
look I show you . Now that's a awesome Radiator'' . I needed something
bigger because I live out here in the desert, at temps of 125 in Death Valley
an in Ridgecrest normal its around 114 . And this new Stroker motor runs
a little hotter than a stock motor .
But because I designed this new radiator, I DO NOT GET ANY ROYALITYS
just for mention it , and Iam not a SALE'S MEN OF ANY KIND . Wate I have to go back an edit some pic's . I have more .
I had to say that, because I don't anyone to thank Iam getting something
for it . Becouse Iam not . Actually I got screwed for making it .
2000 WJ 4.0 NEW 4.6 stroker. W/ 4'' Tera Flex Long arm kit, KING 2.5s w/res front,2.5 Kings w/res Rear,Tom wood front drive, 33 x 15s KM2s, Bassett 15'x8 ,fully addjustible Tera flex Track bar, IRO 3link rear, EBC Dippled & sloted front disks, EBC green stuff pads, Iceland off road fender flairs''.
WJ2000 is offline
post #18 of 32 Old 09-02-2013, 12:47 PM
WJ2000
Here's what it looks like, if you need more, just let me know .
WJ2000 is offline
post #19 of 32 Old 09-02-2013, 12:53 PM
briandor
It probably would be helpful to have a part number and how to go about getting it. Doesn't seem to be anything listed on Griffin's site.
briandor is offline
post #20 of 32 Old 09-02-2013, 12:57 PM
WJ2000
Sorry yeah I got that . I'll get that soon . On the phone now .
WJ2000 is offline
post #21 of 32 Old 09-02-2013, 01:44 PM
WJ2000
Well I cant find the # number, Its on my old computer , So'll have to Pat at griffin
1 800 722 3723 , There is an discount available, for beening an Jeep Forum member
Pat may have an little hard time remembering this , so you'll have to do a refresh '' Lol
What your looking for is an 99-04 Jeep Grand Cher,4.0,, Built by William Glover . 3 years ago
He called it { WILLIAMS GRAND CHER } That should get you though the front door .
WJ2000 is offline
post #22 of 32 Old 09-02-2013, 02:37 PM
cbake67
2003 WJ
To the OP have you tried pressure testing the cooling system yet? After the rebleed with the system topped off, a pressure tester would definitely prove if its leaking or not.
cbake67 is offline
post #23 of 32 Old 09-02-2013, 03:55 PM
WJ2000
I thank I know whats going on, But first we have to wait for Buddy to do more testing .
it has some thing to do with the 0330 .
WJ2000 is offline
post #24 of 32 Old 09-02-2013, 08:00 PM Thread Starter
scross1220
2012 WK
Going to have it pressured tested in the morning. Going to drop it off on my way to work. I will know soon enough. Will let you all know.
Thanks
______ooooo
/__l_l_,\____\,___
post #25 of 32 Old 09-02-2013, 08:03 PM Thread Starter
scross1220
2012 WK
When I did the stroker build I replaced the head with 0330 TUPY casting. The old head had a crack between cyl 3 and 4. Probably explains why I had a piston skirt blow on #3
______ooooo
/__l_l_,\____\,___
post #26 of 32 Old 09-02-2013, 09:38 PM
WJ2000
OK that's great . Nice work . Did you order an 2.5 Kolac exhaust system yet . Well you probably don't need any more power . Lol .
WJ2000 is offline
post #27 of 32 Old 09-02-2013, 11:45 PM
texlurch
What about your radiator cap? Mine was loosing a bit now and then and a new cap cured it.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #28 of 32 Old 09-03-2013, 06:53 AM Thread Starter
scross1220
2012 WK
New cap and everything. Just had the pressure test done and all is fine with it. Heater core ok to. Tech says it should be setting down now so not to panic and wait a few more weeks and see what happens. He did note that my mixture was a tad weak so he drained the overflow bottle and added straight HOAT coolant to it.
______ooooo
/__l_l_,\____\,___
post #29 of 32 Old 09-03-2013, 06:55 AM Thread Starter
scross1220
2012 WK
I need to call him and get that hi flow cat we talked about. I been lacking due to funds lately but I need to move forward on it. That is the only part of the exhaust that I did not upgrade as of yet.
______ooooo
/__l_l_,\____\,___
post #30 of 32 Old 09-03-2013, 09:19 AM
WJ2000
Right on . Iam just wating for the tail pipe . I have been slacking a little bit myself . An ordered his exhaust system an long time ago . But now Iam almost there . You know . Lack of funds its really sucks . I also started a new thread about him exhaust system called kolac exhaust systems on this forum . As well as the Griffen radiator up grade I did . So if you want to that . Let me know before you order . I'll help you out .
WJ2000 is offline
