My WJ Hidden Winch Plate - Page 7 - JeepForum.com
post #91 of 274 Old 02-09-2013, 01:10 PM
texlurch
some teaser pics
Mounted winch upside down
If I knew then what I know now, I would have found a winch with a removeable solenoid box.. would have been able to completely hide the thing.
It's a Recon 10500 waterproof winch, so we'll see how it holds up
I still need to build a tube cage around the bottom of the radiator support, and tie it back to the winch plate.
I modified the Fawkes mount to move the bullbar higher, to fit the hawse plate in the opening.
More pics when I tear it back apart and finish weld everything in place.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #92 of 274 Old 02-09-2013, 01:51 PM
PhantomWJ
2003 WJ
Originally Posted by texlurch View Post
some teaser pics
Nice, but where are the real pics of the winch?
Looks clean.
PhantomWJ is offline
post #93 of 274 Old 02-09-2013, 01:55 PM
texlurch
Looks clean.
Watcha mean "real pics"?
You can see the solenoid box in the pics.. rest is behind the bumper.
FYI that lower unpainted tube is 1-1/4 rollbar tubing.
texlurch is offline
post #94 of 274 Old 02-09-2013, 03:30 PM
BrentConn
A lot of work but looks great..
2004 Laredo. 2 BB 265/75/16. I 6. 117k D.D.
BrentConn is offline
post #95 of 274 Old 02-09-2013, 05:43 PM
texlurch
Well, upon further review I am an idiot... LOL!!
Control box does indeed come off the winch, and now the stock Laredo bumper fits with only one "tooth" removed for the clutch handle.
Tomorrow I search for a spot for the control box, and some extension cables to reach the winch. Looks like it may fit under the drivers headlight.
More pics when I get the "new" mount figured out. I can tell you that nothing more than the clutch lever hangs down in view.
texlurch is offline
post #96 of 274 Old 02-10-2013, 04:13 PM
texlurch
Rev 2.
The solenoid and remote box fit under the drivers headlight.
Requires about 20" extensions on the 3 cables to the winch.
I trimmed the "ears" off the front corners of the winch where the solenoid box mounted, to allow the facia to fit flush with no trim.
Also allowed moving the bottom protection bar I added back about 1 inch, so it now is above and the behind the Fawkes shackle tabs.
I have a hoop to add under the front radiator support, and it will bolt to a couple tubes coming back from the lower protection bar, to protect the bottom of the hoist and stiffen the radiator support.
Those will pass thru the lower grill opening so no loss of clearance either.
Latest version, with the stock Laredo bumper.
texlurch is offline
post #97 of 274 Old 02-10-2013, 04:16 PM
platinum5.9
2003 WJ
I'd be curious to see how it looks with the bumper off.
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #98 of 274 Old 02-10-2013, 04:25 PM
texlurch
I'll take more pics tomorrow when I get all the final welding done and clean everything up.
Basically the bumper support is cut from frame to frame, winch plate is mounted on top of frame rails, upside down.
I have two 1/4 inch "L" plates to weld to the winch plate and sides of the frame rails. Winch plate is 1/4 inch as well, I cut and modified it to fit the way I wanted.
I moved the oil cooler to sit in front of the flange on the winch plate; I wanted to keep it for strength.
Here is the plate I used:
http://www.ebay.com/itm/SPYDER-07-11...f68808&vxp=mtr
texlurch is offline
post #99 of 274 Old 02-10-2013, 06:06 PM
EvilEagle
Very impressive. Good job man.
EvilEagle is offline
post #100 of 274 Old 02-10-2013, 06:17 PM
JimmydaGreek
2015 JK Wrangler
Very nice!
JimmydaGreek is offline
post #101 of 274 Old 02-11-2013, 06:14 PM
texlurch
Permanently welded in place now.
Hooked it all up and works as it should.
Tomorrow I finish welding on the brush guard and verify my tube support for the radiator brace clears the facia, and put it all back together.
Still need to wire the KC lights up as well.
Here are some details of the bracket.
texlurch is offline
post #102 of 274 Old 02-11-2013, 07:03 PM
wvracer821
nice job. i really like the end result. i hope to take on this project along with a tire carrier in the summer, thanks for the ideas
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #103 of 274 Old 02-11-2013, 07:05 PM
texlurch
Tire carrier is next, after I get the front buttoned up
I have wireless relays for the lights, to operate off the overhead console switches.
texlurch is offline
post #104 of 274 Old 02-11-2013, 07:57 PM
fosterjd79
I would put some loom tubing over those winch wires to prevent fraying.
fosterjd79 is offline
post #105 of 274 Old 02-11-2013, 08:06 PM
texlurch
On the list for tomorrow
texlurch is offline
