My WJ Hidden Winch Plate - Page 18 - JeepForum.com
post #256 of 274 Old 06-14-2013, 09:14 PM
texlurch
Originally Posted by fast540 View Post
Is it just the one bolt and the single weld point per side holding it together?
Wondered that myself.. I plan to go back and add a couple bolts in shear, just for piece of mind.. and mine is welded solid across the top, and down the sides on the frame.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #257 of 274 Old 06-15-2013, 10:18 AM
sposato95yj
temporarily, yes. i had to get it together for the Bantam Jeep Heritage show that i have to work tomorrow. so i knew i wasnt going to be using it and i wont use the winch til i finish welding underneath.
sposato95yj is offline
post #258 of 274 Old 07-23-2013, 11:47 AM
=KZ=
Can someone tell me will a warn vr8000 work with this setup?
I have a chance to buy a used one for 1/2 price.
Sent from my SAMSUNG-SGH-T989 using JeepForum
=KZ= is offline
post #259 of 274 Old 07-25-2013, 06:35 AM
whosyadadie02
Any update on this
whosyadadie02 is offline
post #260 of 274 Old 07-25-2013, 07:19 AM
tim0
Very nice looking.
Thanks
tim0 is offline
post #261 of 274 Old 07-26-2013, 05:59 PM
sposato95yj
Yes it should.. They are almost identical to the smitty in dimensions so it shouldn't be an issue!
post #262 of 274 Old 10-26-2013, 02:26 PM
=KZ=
I am also wondering if this ends up with the winch plate right in front of or beneath the rad. One concern is that a relatively small front end hit might send the plate into the rad which could really ruin your day. any insight on this?
=KZ= is offline
post #263 of 274 Old 10-27-2013, 12:50 AM
texlurch
it is right in front of the radiator/condensor; same as the thin stamped rail is now.
texlurch is offline
post #264 of 274 Old 10-30-2013, 02:00 AM
=KZ=
Thanks for the reply. So I take it then that it is safer for the rad or equal to stock setup?
=KZ= is offline
post #265 of 274 Old 10-30-2013, 03:43 AM
texlurch
It is closer than the stock crossmember to the condensor, but quite a bit thicker.
You do loose the foam under the bumper cover, so there is no "give" for minor fender benders.
So if you are prone to running into stuff regularly, might not be for you.
texlurch is offline
post #266 of 274 Old 12-02-2013, 10:03 AM
kaserWJ04
I really like the look of this!
kaserWJ04 is offline
post #267 of 274 Old 01-13-2014, 05:32 PM
fayceoff
fayceoff's Avatar
These are awesome ideas... Can't wait til I get the cash so I can try my hand at this.
fayceoff is offline
post #268 of 274 Old 05-11-2014, 12:32 PM Thread Starter
gcjeeping
gcjeeping's Avatar
Saw a post linked to this. Was done really well.
_____________
gcjeeping is offline
post #269 of 274 Old 05-11-2014, 09:28 PM
Terminal
Originally Posted by MadMonk View Post
Damn, that's sweet!
Couldn't have said it better myself.
Terminal is offline
post #270 of 274 Old 05-12-2014, 05:51 PM
PhantomWJ
2003 WJ
So. how does the final product look?
PhantomWJ is offline
