#1 | |
my wj front winch bumper build
i started my front winch bumper today, i have the winch mount all done and now have to piece together the 3/16 for the body of it. tell me what you guys think so far.
99 WJ 4" SA lift rolled fenders 35" bfg km2 tons of fabrication |
#2 |
I'd love to have a welder to build my own bumper.
2001 4.7l Limited WJ IRO 6.5" Critical LA, Lonestar Incline Bumper, XRC-8000 Comp Winch, 33" BFG All-Terrains, and a long list of other stuff. |
#3 |
Looks awsome so far deffinately picture document the rest of the build as you go this is inspiring
#4 |
Frobot Fabrication
Its lookin good, but you have no support on the mounting plates for upwards or downwards pressure, as of now from what i can see your mounting plates would just bend where they meet the unibody.
Very interested in how it turns out, you have a good start!
Frobot Fabrication Facebook 01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle. Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387 |
#5 |
Location: Vancouver, British Columbia, British Columbia
Looks great so far, X2 on beefing it up or it will bend at the unibody.
- Russ 5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof |
#6 |
im actually going to make some sort of bracket for it, how do you guys suggest i beef it up?
#7 |
maybe something that braces off of the core support? not sure how strong it actually is but i know ive bumped mine a few times and its seemed to hold up so far
2000 Jeep Wj 4.7L V8 flowmaster classic 40 exhaust with 3' downpipe, K&N CAI blackened but not blacked out tails 265/75/r16 Firestone Destination MTs 16x7 cragar soft 8's IRO 4" LA front windows 35%, Alpine idaX100 deck, polk audios all around |
#8 |
I would try and find some 1/4" 4x2 angle and use that for a mount or even some 5/16 - 3/8" angle if you can. I can't tell for sure from the pics, but did you sandwhich the unibody in between your mount and a piece of steel inside the unibody channel? It looks like you did, but I can't tell for sure. It looks real good so far.
[B][FONT="Arial"][SIZE="4"][COLOR="Blue"]"GRITZ"[/COLOR][/SIZE][/FONT][/B] [B]99 Jeep Grand Cherokee Laredo[/B] - [COLOR="Red"][SIZE="4"]Totalled[/SIZE][/COLOR] -3" lift w/Bilsteins - - - - - - - - - - - - - - - - - -30.5" Pirelli Scorpion ATRs -[URL="http://www.jeepforum.com/forum/showthread.php?t=494045"]Clear Lenses[/URL] - - - - - - - - - - - - - - - - - - -[URL="http://www.jeepforum.com/forum/showthread.php?p=5229329#post5229329"]Cobra 75 CB w/Wilson 4' Antenna[/URL] -[URL="http://www.jeepforum.com/forum/showthread.php?p=7008250#post7008250"]Home-Brew Discos[/URL]- - - - - - - - - - - - - - - - - -[URL="http://www.jeepforum.com/forum/showthread.php?t=734768&highlight=diamond+plate+hitch+cover"]Diamond Plate Hitch Cover[/URL] [B]07 Compass (wife's ride)[/B] -Stock |
#9 |
If you had a 1/2 piece of steel on edge under the flat steal you have bolted on it would give support for pulling up and down. that flat steel you used looks pretty light and it will bend. It looks like a piece may fit down the middle of each flat iron you have, right between the bolts. You could then 45 it back and it would also work as a clevis point.
Reg 93 ZJ 5.2 auto 2" bds lift and shocks, 31" tires 04 GC Limited 4.7 Wife drives this one |
#10 |
1/2" would be way overkill IMO. If you were just going to add a single piece welded in the middle, then 1/4" or a little thicker should be plenty. You'd bend the unibody before you'd bend that type of set-up.
#11 |
im just going to either make a bracket from the mount to the metal bumper on the car or double up the bracket with another 1/4 flat stock. but thanks for the great comments. im working on it tommorrow for a while, ill take pics =]
#12 |
Looks good so far. I installed a Warn front receiver on Laredo for the winch and can use it front or rear that way but for my limited (which is my next project) I like what you've done. Looking forward to seeing more pics! I also installed 2 additional grade 8 bolts (1 each side) to the hitch for a total of 6 bolts. I've heard that the front receiver, which is very similar to what you've done, strengthens the uni-body.
#13 |
didnt get much done today, had to organize a new craftsman full lower and upper tool box loaded with air tools, sockets and so much more, got it for 300 =] felt like xmas haha
but i just tacked up some flat stock for the winch part and started to drill out shackle mounts. ![]() ![]()
#14 |
finally my metal came in, i didn't realize how long it takes to figure out the exact angle and where to cut and blah blah, got a little bit done today. i still have to angle up from the top to the headlights and piece together the rest, the fun part =/.
here are some pictures. ![]() ![]() ![]()
#15 |
i like keep it going, im gonna make one soon as well..
99WJ 4.0 IRO 3", SYE, D30 aussie/8.8 aussie, 4.10s, 33's, skids/bumpers |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
