My v8 has 242j??? - Page 2 - JeepForum.com
post #16 of 57 Old 01-28-2013, 06:00 PM
adavis39
Originally Posted by ZB_WJ View Post
Most limitless came stock with the 272, that's why the 242 is rare. It's considered a downgrade and not a lot of people ordered a downgrade. IIRC the Olympic edition was an export only model. I may be wrong
yeah , just found it on wjjeeps......a Canadian option
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #17 of 57 Old 01-28-2013, 07:03 PM Thread Starter
65novalt1ss
Is there any way an hd tail can be put on a standard housing?
65novalt1ss is offline
post #18 of 57 Old 01-28-2013, 07:07 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
No. I tried haha
BTW, there has been a few threads over the years regarding the tags on 242s. They used many different designations, 242j, 242wj, etc. They dont really mean a thing and were randomly distributed on the LD and HD models. I believe the tag on my HD reads 242wj.
~James
ezflip is offline
post #19 of 57 Old 01-28-2013, 07:23 PM
adavis39
Originally Posted by ezflip View Post
No. I tried haha
same here....mine reads 242 WJ
TNJEEPS.COM
BUILD:
adavis39 is offline
post #20 of 57 Old 01-28-2013, 07:32 PM
coloradowjowner
Congratulations on having one awesome and rare combination.
coloradowjowner is offline
post #21 of 57 Old 01-28-2013, 10:03 PM Thread Starter
65novalt1ss
Alright well even tho mine only took a quart and a half i guess everything else says its the correct one. Thanks for all the info everybody.
post #22 of 57 Old 01-29-2013, 07:51 AM
Red350ss
Rare bc its labeled wrong? Wjjeeps says it should hold 6.6 pts which i figured around 3.5 quarts. Only held about 1.5 quarts. Thoughts?
When I looked today, wjjeeps shows the 242 only holds 2.85-3.0 pints in the "maintenance" section, but under the "transfer case" section it does indeed show the HD capacity at 6.5 pints....looks like an error on their site. As long as you drained it and filled back to the fill hole level you are fine.
Red350ss is offline
post #23 of 57 Old 01-29-2013, 08:11 AM Thread Starter
65novalt1ss
I see that now. Thanks Red. I wonder if there is even a difference in capacity between the two? The maintenance section doesnt differentiate. Mute point now i guess. I drained and filled until it came out the fill hole. 4wd works so thats all that matters i guess. Thanks again.
post #24 of 57 Old 01-29-2013, 11:48 AM
ZeJokee
No. I tried haha
My 242 came from a I6 and I swapped it behind my 4.7l. It was tagged 242wj but does not have the aluminum tail cone. It is just a standard 242.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #25 of 57 Old 01-29-2013, 11:58 AM
MiCrOz
AllData lists fluid capacity at 3 pints, which equals 1.5 quarts. WJJeeps mixed up the fluid capacity of the transmission (6.5) for the transfercase.
2000 WJ 4.7 (work in progress)
Offroad: 6.5" IRO long arm high clearance, Bilstein 5125 - 35x12.5 KM2's - 242 swap - 4.56 w/ stock Varilok
Onroad: Spyder Full LED tails, Projector Heads w/ DDM 6k slim HID, Addco rear sway
MiCrOz is offline
post #26 of 57 Old 01-29-2013, 03:06 PM Thread Starter
65novalt1ss
Now that makes sense. Good catch. What is alldata? A website?
post #27 of 57 Old 01-29-2013, 04:57 PM
shepd
Most limiteds came stock with the 272, that's why the 242 is rare. It's considered a downgrade and not a lot of people ordered a downgrade. IIRC the Olympic edition was an export only model. I may be wrong.
The olympic was basically a v8 laredo with selectrac, limited wheels and a limited grill. Oh yeah and a leather steering wheel.
Now I get the rarity! I think I now understand why the original buyer bought what he bought. He got the fully optioned limited package, but with the 242 tcase, and with a tow bar. I think he intended to do a LOT of towing with the Jeep, and probably not a lot off offroading. Explains why the tcase selector needs two hands and a lot of body weight to move, and the part time light on the dash hardly ever works right (probably was left in 2WD almost exclusively and I am told the part time sensor needs some moving about to lubricate it otherwise it gets stuck). The engine had also been replaced--perhaps due to excessively heavy towing? Who knows...
shepd is offline
post #28 of 57 Old 01-29-2013, 05:07 PM
ZeJokee
It should shift with ease. At least every 242 I have had has shifted like a breeze.
ZeJokee is offline
post #29 of 57 Old 01-29-2013, 05:08 PM
shepd
More for me to fix then. I have a feeling I'll just leave it in Full-Time and ignore it, the rust has almost taken the subframe anyways.
shepd is offline
post #30 of 57 Old 01-29-2013, 05:14 PM
the88thpianoman
2003 WJ
When I first test drove my WJ, the shifter just about required putting both feet on the dash and pulling the shifter backwards. The case gets extremely stiff if not shifted for a couple years or 40k miles.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
