Is my service tech bs'ing me? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Is my service tech bs'ing me?
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 03-23-2010, 09:37 PM   #1
bb1968
I had just changed my spark plugs and had my 2004 4.7 WJ in the shop and was talking to the tech about my lousy gas mileage. He told me that any time the plugs are changed I need to take it to the shop to have them reprogram the computer (at $95). Is he giving it to me straight or will the computer relearn by itself?
bb1968 is offline   Reply With Quote Quick reply to this message
Unread 03-23-2010, 09:38 PM   #2
coldcanuck
Bs!!!!!!!!!!!!!
99 WJ 4.0, 3.0" IRO, 265/75/15, 160,000km's and every km more something else goes wrong:)(sold)
97 XJ Rubicon 5.5" long arm 33's(sold)
07 WK wimpy V6, bone stock, not allowed to touch it(its the wife's)
coldcanuck is offline   Reply With Quote Quick reply to this message
Unread 03-23-2010, 09:38 PM   #3
Bane7962
Bane7962's Avatar
He's so full of **** his eyes are brown..
Working with cars is a little like a really awesome date: you start out expecting this to be something simple and straightforward; four hours later you're laying under her, panting and cursing, and things are a lot more complicated than you thought.
When my Jeep stops making strange noises, I become concerned. That usually means I have to go back and find whatever fell off.
Bane7962 is offline   Reply With Quote Quick reply to this message
Unread 03-23-2010, 09:40 PM   #4
junkyarddog
Originally Posted by coldcanuck View Post
Bs!!!!!!!!!!!!!
X2 I call BS
junkyarddog is offline   Reply With Quote Quick reply to this message
Unread 03-23-2010, 09:40 PM   #5
rooster51
If they do state inspections, report them to the state police. HUGE crock of poo.
Terry
rooster51 is offline   Reply With Quote Quick reply to this message
Unread 03-23-2010, 09:40 PM   #6
xJoshxx
xJoshxx's Avatar
2012 WK
wanna know the $95 dollar trick they'll do?
go out Pull your positive battery cable and then turn the key to drain all the voltage.
reconnect battery and start it up and let it idle for a few minutes then go drive it.
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2
2012 WK2 SRT8
xJoshxx is offline   Reply With Quote Quick reply to this message
Unread 03-23-2010, 10:14 PM   #7
straty1987
i really like to know what resetting the computer and new spark plugs have to do with eacgh other?
when the plugs are being changed the battery should be disconnected and when you put it back on the computer should rest itself anyway
xjoshx, why the positive and not the negative cable?
straty1987 is offline   Reply With Quote Quick reply to this message
Unread 03-23-2010, 10:20 PM   #8
Spike300
BS!!, find another mechanic.
[url]http://www.jeepforum.com/forum/f197/camo-beast-975063/[/url]
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -[COLOR="Red"]Optima[/COLOR] -E3 plugs-[COLOR="DarkGreen"]Cu[/COLOR]st[COLOR="DarkGreen"]om[/COLOR] Pa[COLOR="DarkGreen"]in[/COLOR]t-Amsoil-Addco Front and Rear-polyurethane bushings
[B]To be installed[/B]: RE gen2 discos, military battery terminals
[B]To be rebuilt:[/B] HP30
[B]To be received:[/B]
[B]To be paid for:[/B]
[B]Next on the list:[/B] complete redo of brakes and
lines
[B]Needed:[/B] fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline   Reply With Quote Quick reply to this message
Unread 03-23-2010, 10:31 PM   #9
UltimatE
Resident Audio Guru
UltimatE's Avatar
always pull the negative cable.
And wow I've never heard of such BS before in my life.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote Quick reply to this message
Unread 03-23-2010, 11:07 PM   #10
22remud
it doesn't matter which cable you pull, most say negative cause there is no shock hazard.
that being said, when you change spark plugs there is technically no reason to remove your battery cables to disconnect power. the only need to do so is if you computer is not tuning itself fast enough.
but either way, disconnecting your battery and turning the key drains the batter and the memory drains allowing the computer to start fresh more or less, and it will learn easier because it is all based on averages.
1998 TJ 4.0L NP231, 4inch skyjacker kit
1992 XJ 4.0L NP231, 6inch Gonzo Lift, Cherry Bombed Exhaust,Custom Cowl Snorkel,33x12.50 BFG km m/t's
22remud is offline   Reply With Quote Quick reply to this message
Unread 03-24-2010, 12:21 AM   #11
ZJ5point2GCL
is this a dealer? or a privet mechanic ?
because its such epic ****
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline   Reply With Quote Quick reply to this message
Unread 03-24-2010, 12:26 AM   #12
CLNinja
BS
oh and did you use platinum plugs? switch back to the stock copper plug and your gas mileage and you will like the difference
[color="#003300"]Matt[/COLOR]
[color="white"][CENTER][size="1"]
[url="http://www.jeepforum.com/forum/showthread.php?t=434081"][color="white"]Click Here For My Build Thread[/COLOR][/url]
[/COLOR][/SIZE][B]**September 2009 Grand Cherokee Of The Month**[/B]
[SIZE="2"][url="http://www.jeepforum.com/forum/forumdisplay.php?f=123"][color="white"]Colorado Jeep Club Member #88[/COLOR][/url][/SIZE][/CENTER]
CLNinja is offline   Reply With Quote Quick reply to this message
Unread 03-24-2010, 01:00 AM   #13
22remud
i have those fancy plasma ones and with my lift and 32's on 3.55 gears i only lost .5 mpg
