my jeep went haywire and now wont turn on... - JeepForum.com
post #1 of 21 Old 05-09-2011, 10:00 PM Thread Starter
hilluhhree
Wj my jeep went haywire and now wont turn on...
2 weeks ago i was driving my gauges went crazy and i looked at my dash to see that my jeep was overheating, i pulled over turned it off and waited a few minutes and then continued home, luckily i was right around the corner from my house. come to find out my fan was not turning on so for the next 2 weeks it sat in my driveway until this past Friday i took it to pep-boys for the free check engine light evaluation when all was said and done it ended up being my cooling fan control module which they wanted to charge me $200 to replace, i bought the module myself for cheap and replaced it in less then 30 minutes, so thinking all was good i take a weekend trip and on the way home my dash starts flickering and my jeep starts running very rough so i pulled over to side of the road and turned it off and it wouldnt turn back on, absolutely no power! so it sat for a few hours and then started chirping... i took both terminals off the battery and let it sit for the night. so today i get home jump start it and stays on for a few minutes the second i give it gas it shuts off... my alternator is not bad... any ideas on what it could be?
*WRENCH*GIRL*
hilluhhree is offline
post #2 of 21 Old 05-09-2011, 10:04 PM
narnwv
narnwv's Avatar
double check the tightness of the battery terminals--even a little bit of leeway, and WJs get crazy.
Could also be a failing battery.
As for giving it gas and it shutting off, will it idle indefinitely?
Do you see a Key with a line through it on the dash? (skis)
BTW--Welcome to the forum!
~Aaron
narnwv is offline
post #3 of 21 Old 05-09-2011, 10:09 PM
IgotJeep99
Wow, 2,221 post :thumbs up:
IgotJeep99 is offline
post #4 of 21 Old 05-10-2011, 12:34 AM Thread Starter
hilluhhree
Narnwv: the battery is barely a year old and I have an alarm that chirps randomly before this issue, like when my neighbor starts her truck my alarm will go off of closing the door to another car does it... I know I need new battery clamps and there is no mil with a key and a line through it, also my ignition has resistance in it and it's going out I can take my key out while driving
*WRENCH*GIRL*
post #5 of 21 Old 05-10-2011, 05:31 AM
georged
Is it TOP SECRET or are you willing to tell us what engine you have?
georged is offline
post #6 of 21 Old 05-10-2011, 06:57 AM
HVACNY
2013 WK
If you know you need new battery clamps then Narn was right on,change those and you should be good to go.
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline
post #7 of 21 Old 05-10-2011, 11:10 AM
Cnolenwj
Kinda sounds like a ground issue, had something similer happen to mine, changed out termnals and not a prob since. Its a good cheap place to start.
2000 wj limited, 4" IRO, long armed front.
Build thread-
North Texas Grands-
Grand Slam Texas-
Grand Slam Texas Group-
Cnolenwj is offline
post #8 of 21 Old 05-10-2011, 12:08 PM
RedlegWJ
Narn wasn't blowin smoke, battery terminals and questionable batteries are a known problem for erratic behavior.
RedlegWJ is offline
post #9 of 21 Old 05-10-2011, 01:13 PM Thread Starter
hilluhhree
its a 4.0... its my red beast as i call her haha... alright so when im replacing the terminals i disconnect it from the battery is there anything special i need to do or know when replacing them like which side to do first?
*WRENCH*GIRL*
post #10 of 21 Old 05-10-2011, 01:48 PM Thread Starter
hilluhhree
this is a picture of my battery and the clamps ill post a link of what my dash was doing after i jump started it and gave it gas and it died...
*WRENCH*GIRL*
post #11 of 21 Old 05-10-2011, 01:57 PM
malibubts
Those terminals and clamps look pretty clean. Have you had the battery tested?
malibubts is offline
post #12 of 21 Old 05-10-2011, 03:25 PM
Cnolenwj
Can you get the jeep to an auto parts store? You can have them test the battery and alt. When you change your clamps out disconect both leads and do witch ever first, they also make some grease for your terminals that reduce corrosion. Also could check connection on starter. Doubt that is the prob but I would still check.
Build thread-
North Texas Grands-
Grand Slam Texas-
Cnolenwj is offline
post #13 of 21 Old 05-10-2011, 05:17 PM Thread Starter
hilluhhree
the negative side doesnt tighten completely... malibubts: the last battery i had, had a bad cell so i got this one last april and didnt have problems except for the alarm randomly going off... Cnolenwj: i cant get it out of my driveway... and on the clamp replacement do i cut the clamp off the wires?
*WRENCH*GIRL*
post #14 of 21 Old 05-10-2011, 05:35 PM
Cnolenwj
Yeah, you have to with the original clamps, new ones will bolt onto the wire, cut as close to the clamp as possible. Its real easy. And if your negitive dosnt tighten all the way im pretty sure thats the problem, same thing happend on mine.
Build thread-
North Texas Grands-
Grand Slam Texas-
Cnolenwj is offline
post #15 of 21 Old 05-10-2011, 05:51 PM
Cnolenwj
Here is a pic of mine, pretty simple, cheap, and straight forward. Let me know how it goes.
Build thread-
North Texas Grands-
Grand Slam Texas-
Cnolenwj is offline
Jeep wont Turn over powers up wont start Please help its been 3 weeks chesapeake WJ Grand Cherokee Forum 9 09-22-2010 09:52 PM
Need Help! 03 WJ wont turn on!! OilTownXJ WJ Grand Cherokee Forum 1 09-12-2010 10:38 AM
Map lights wont turn off 93wagon WJ Grand Cherokee Forum 5 08-16-2010 10:29 AM
99 Jeep WJ Limited Has Gone Haywire Jacktam WJ Grand Cherokee Forum 1 05-11-2010 06:15 PM
key wont turn please help Arkansas_WJ WJ Grand Cherokee Forum 24 03-17-2010 10:34 PM
