my jeep stalls out randomly - JeepForum.com
post #1 of 3 Old 08-23-2014, 03:19 PM Thread Starter
bigstevo0727
I have a 99 4.0 and it will just randomly stall out driving down the highway or driving through town. It seems like it starts doing it after ive been driving it for a while that day and it gets warmed up, the engine will stay running but there is no power to it and when I hit the accelerator the engine actually dies down some. And byvthe time I get pulled over and stopped on the side of the road, the engine will cut off completely. Sometimes it will start right back up other times it wont stsrt for another 20 minutes. Its not throwing any codes and Its not the fuel pump or fuel filter
bigstevo0727 is offline
post #2 of 3 Old 08-23-2014, 04:15 PM
wsar10
2003 WJ
Try to retrieve any stored codes. No CEL does not mean no codes all the time, key: on off on off on look at odometer.
This issue sounds similar to a CKPS failure.....crank position sensor.
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #3 of 3 Old 08-23-2014, 04:21 PM
doityourselfMM
doityourselfMM's Avatar
If it was me, the first thing I would do (unless you just did it) is pull the battery cable clamps off the battery posts, and clean both mating surfaces with a battery post/clamp wire brush. Don't assume that they are OK unless you have already done it. Don't get bitten by something free and easy to verify.
The WJ works in mysterious ways!
doityourselfMM is offline
