My jeep no longer pisses excellence! - JeepForum.com
post #1 of 22 Old 07-27-2007, 10:02 AM Thread Starter
kwb18
2011 WK
I have an 00 grand cherokee. Lately it's been giving me a lot of problems! It's been having issues starting and then one day I was driving it and all my lights starting going crazy as well as my gauges. My ABS and brake light came on. I pulled over, turned it off, let it sit and started it back up. No more ABS or brake light. When I went to start it back again, it wouldn't start and heard a bunch of clicking noises. My jeep wouldn't even turn over, the gauges just sat there partying back and forth. When I pushed on the brake, it started right up.
I took my car to have the battery tested and the alternator, they said the alternator was bad. Got a new one, few days later, the problem came back. Now when I drive, the ABS and brake light both come on but when I turn it off, it goes away. Basically, it comes and goes. I had to get it jumped yesterday and for a while it wouldn't stay on by itself. Any ideas on what's going on with my jeep?
kwb18 is offline
post #2 of 22 Old 07-27-2007, 10:14 AM
Cebby
Corrosion and/or loose battery connection. Ongoing problem for many of us.
Remove battery connections, use a wire brush or light grit sand paper to remove the corrosion from both the battery posts and the cable ends - eb sure to get down to bare metal. Buy larger replacement bolts (drill out the existing lugs so they fit) and then tighten the terminals to the battery "gorilla tight". OEM cable bolts only allow chimpanzee tight before breaking.
Your Jeep will soon be pissing excellence all over the place again.
If the problem persists, its the battery.
2000 WJ Laredo 4.0 4x4 Taupe Frost - Stroker | Clayton LA w/3" Lift | 33's on JK 17's | Axles next
Cebby is offline
post #3 of 22 Old 07-27-2007, 10:22 AM
MuddyLuxury
MuddyLuxury's Avatar
another quick easy fix, use a set of vise grips to pinch the terminal loops tighter. kinda into an egg shape, then you have to tap them onto the terminals, and everything has been running much smoother since then
-Jeb
99 WJ 4.7V8 selc-trac swap
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
in the works... lots deployments are great for jeep budgets
Go Doorless!
Things i need..
good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share
Originally Posted by 5.9 ANDY
i would do the rear.
MuddyLuxury is offline
post #4 of 22 Old 07-27-2007, 10:57 AM Thread Starter
kwb18
2011 WK
If it was a battery issue, why would only the ABS and brake lights come on and nothing else?
kwb18 is offline
post #5 of 22 Old 07-27-2007, 10:58 AM
JayIV
JayIV's Avatar
Cause electrical systems do wierd chit when the ground isn't 100%
2004 Overland
JayIV is offline
post #6 of 22 Old 07-27-2007, 11:34 AM
MuddyLuxury
WJs do not react well to battery issues, i thought my entire computer gave up the ghost the first time this happend
-Jeb
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
Go Doorless!
Things i need..
post #7 of 22 Old 07-27-2007, 12:39 PM
sand zj
sand zj's Avatar
Make sure ya'll are also cleaning the grounds really well, not just the battery connections but the ones that go to the block and chassis as well. I would reccomend installing with dielectric grease to seal out farther corrosion.
Dan
If you don't get stuck, keep trying!
'96 ZJ 7" LA, 318, 231, 8.8 (welded), d30 (LockRight), 4.10's, 33x13.5x16 TSL's, no interior...
sand zj is offline
post #8 of 22 Old 07-27-2007, 01:11 PM Thread Starter
kwb18
2011 WK
Is there a reason it will only start if I push the brake?
kwb18 is offline
post #9 of 22 Old 07-27-2007, 01:44 PM
MuddyLuxury
id10t protection.. i think its like the park lock out starting
-Jeb
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
Go Doorless!
Things i need..
post #10 of 22 Old 07-27-2007, 01:48 PM Thread Starter
kwb18
2011 WK
id10t protection! haha! I use that all the time on people, "must be an id10t problem!" haha!
kwb18 is offline
post #11 of 22 Old 07-27-2007, 01:52 PM
MuddyLuxury
then you will like pebkac, and ODMF
problem exsists between keyboard and chair
one dumb mother ****er
i close out tickets all the time at the office with those resolution codes, the other engineers i work with laugh and the project manger has no clue
-Jeb
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
Go Doorless!
Things i need..
post #12 of 22 Old 07-27-2007, 01:55 PM Thread Starter
kwb18
2011 WK
HAHAHAHA! That's awesome! I'm gonna start using those around my office! haha!
kwb18 is offline
post #13 of 22 Old 07-27-2007, 02:17 PM
jp88
I had a problem with my battery that would cause my vic to reset and my abs and brake lights to come on once every couple of days. When I was looking at the battery connections I noticed that one of my terminals coming out of the batt was cocked to the side. I replaced my batt and the problems went away.
96 zj 5.2l v8 stock
jp88 is offline
post #14 of 22 Old 07-27-2007, 02:27 PM Thread Starter
kwb18
2011 WK
Is changing a battery every 4 years the best? I've heard so many things. What's everyones opinion. It's been about 5 years with mine.
kwb18 is offline
post #15 of 22 Old 07-27-2007, 03:16 PM
MuddyLuxury
idk if its like an oil change, i change them as needed, i think my moms 99 rubasu is still running the orginal battery, and my dads 98 caravan still has the orginal battery
-Jeb
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
Go Doorless!
Things i need..
so my jeep is no longer a grand cherokee str8stock4l ZJ Grand Cherokee Forum 41 03-04-2009 03:58 AM
Longer Springs ? Redstarlover ZJ Grand Cherokee Forum 5 08-29-2008 06:00 PM
Do I need longer CA's wheelNC93 ZJ Grand Cherokee Forum 3 08-18-2007 04:37 PM
Well my Jeep is no longer drive-able... Again (Pics) Ruffy ZJ Grand Cherokee Forum 29 02-26-2005 09:35 PM
How much longer? ILoveto4x4inNC ZJ Grand Cherokee Forum 4 03-24-2003 02:14 PM
