My first WJ... Help me figure out a couple of things please :) - JeepForum.com
post #1 of 14 Old 08-06-2011, 10:19 AM Thread Starter
TeeJay00
First of I wanna figure out the wheels that came with my '04 Limited WJ!
I pulled the build sheet from the dealership and it says that it shold have a matching spare wheel. But I have the Avila wheels on the ground and a Silverblade #3 as a spare wheel. So which where replaced by the previous owner???
TeeJay00 is offline
post #2 of 14 Old 08-06-2011, 10:24 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Well, if you have the build sheet it should tell you which wheels you had originally. But if I had to guess, the 04 probably had the silverblades stock and got a set of 4 Avilas to replace them. The only reason I say that is that people more often replace the wheels on the vehicle than replace the spare.
~Richard
billzcat1 is offline
post #3 of 14 Old 08-06-2011, 10:27 AM Thread Starter
TeeJay00
The build sheet only says "WGF: Wheels - 17X7.5 Alm, Sparkle, Accent"
TeeJay00 is offline
post #4 of 14 Old 08-06-2011, 10:31 AM Thread Starter
TeeJay00
The other issue is the amplifier... There seems to be a missing nut or something from it's mounting... What's missing here???
TeeJay00 is offline
post #5 of 14 Old 08-06-2011, 10:35 AM
JerzeyBoyWJ
2003 WJ
well the wheels ..that are in the last picture is a 17 inch rim...and the top ones are 16s
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #6 of 14 Old 08-06-2011, 10:38 AM Thread Starter
TeeJay00
Nope... Those are 17's aswell which is why I'm confused
TeeJay00 is offline
post #7 of 14 Old 08-06-2011, 10:44 AM
billzcat1
2003 WJ
Per http://www.wjjeeps.com/wheels.htm#WHEELS - sales code WGF corresponds to the Silverblade #3.
On your amp, all that is missing is a nut like you have on the other mounts. If it really bothers you, I think they are M5x1.00 thread.
~Richard
post #8 of 14 Old 08-06-2011, 10:47 AM Thread Starter
TeeJay00
Yeah that was my guess for the wheels... But I kinda like those Avilas
Anyway about the amp... That bolt isn't attached to the floor or to anything!!! I thought there might be something else missing other than the nut... A bracket perhaps???
TeeJay00 is offline
post #9 of 14 Old 08-06-2011, 10:50 AM
shockracer
Take a can of air to that amp, that's a lot of dust on it= bad for electronics, that bolt would cost no more then $2 from a dealer. Seems like the last owner had messed with the jeep, I'd look deeper into the jeep and see what else has been messed with.
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #10 of 14 Old 08-06-2011, 10:59 AM Thread Starter
TeeJay00
Oh don't get me started on the messing around with the jeep thing It's bad enough that he had the front axles and drive shaft removed to disable the 4WD system, the Quadra-Drive system
But overall the interior and exterior is in great condition which I thought would matter most... All missing mechanical parts are easy to replace here and I am in the process of doing so before I start with heavy modifications
TeeJay00 is offline
post #11 of 14 Old 08-06-2011, 11:17 AM
billzcat1
2003 WJ
I like the Avilas too.
As for the amp, it does sit on a bracket which has 3 welded studs on it that retain the amp. Then the bracket is affixed to the floor with a few studs that are under the amp. It all looks just like mine when I took it apart to pull the seats and carpet to replace the front parking brake cable (that was FUN).
Just replace the nut and you'll be good.
~Richard
post #12 of 14 Old 08-06-2011, 11:18 AM
billzcat1
2003 WJ
Did he leave the outer CV in the hub? If he had the entire axle out, I would expect the wheel bearings to be completely destroyed.
~Richard
post #13 of 14 Old 08-06-2011, 11:28 AM Thread Starter
TeeJay00
Yes he did a pretty good job with that. Outer CV in the hubs, sealed the axle tubes and filled the diff with grease to preserve it... I already checked the gears and they look perfect I just hope that the vari-lok is still working after I re-install those axles and drive shaft
TeeJay00 is offline
post #14 of 14 Old 08-06-2011, 12:57 PM
billzcat1
2003 WJ
Yeah, who knows what the motivation was for disabling the QD system. Doing burnouts? Saving 1 mpg? Hopefully the diff and transfer case are good.
~Richard
Can anyone help me figure out what sensor this is!? brycherokee87 WJ Grand Cherokee Forum 9 02-23-2012 08:57 AM
Cant figure it out! alyce001 WJ Grand Cherokee Forum 1 06-17-2011 08:25 AM
Trying to figure out the best way to save my WJ from the salt... FleshEater WJ Grand Cherokee Forum 10 05-07-2011 05:37 AM
Technical advice on a couple things 02 grand 4.0l 95k(ready to read?) 02grandy WJ Grand Cherokee Forum 2 04-18-2011 09:59 PM
cant figure out where im leaking P/S from?? XJ57 WJ Grand Cherokee Forum 8 11-12-2010 08:05 AM
