My butt's getting cold lol - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > My butt's getting cold lol
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 11-24-2013, 12:34 PM   #1
dagangsta
Wj My butt's getting cold lol
So winter is coming and my 02 WJ Overland's driver's side (note that I'm in UK where driver's side is USA's passenger side) seat stopped working. The light on the switch goes on but the seat is still cold as hell on both settings. I was wandering whether it's the fuse or the heating element was broken. I'd rather get it fixed up before temp. gets below 0C or 32F lol. But it's annoying so if you guys could help me with that.
dagangsta is offline   Reply With Quote Quick reply to this message
Unread 11-24-2013, 01:24 PM   #2
rickcricket
Common problem. Mine was a burnt wire under the leather seat. I re-soldered it and now it works great again. Give that a try. There is a how to somewhere if you google it.
rickcricket is offline   Reply With Quote Quick reply to this message
Unread 11-24-2013, 01:44 PM   #3
dagangsta
Wj
Thanks buddy. I'll try that
Unread 11-24-2013, 02:34 PM   #4
MadderThanMax
Fart & Light it .. problem solved..
MadderThanMax is offline   Reply With Quote Quick reply to this message
Unread 11-24-2013, 04:00 PM   #5
dagangsta
Wj
Doesn't really work
Unread 11-24-2013, 04:50 PM   #6
MuddyWJ
Originally Posted by dagangsta View Post
Doesn't really work
Oh it does though!!!! Serious question though, does everyone's seat get hot or just the back. My seat has never gotten hot and am wondering if I need to start hunting?
MuddyWJ is offline   Reply With Quote Quick reply to this message
Unread 11-24-2013, 05:00 PM   #7
rickcricket
Both should heat up. My guess is you have a problem. It is seriously the easiest most rewarding fix you can make when yours is broken.
Unread 11-24-2013, 05:01 PM   #8
MuddyWJ
Damn 2 years I thought Chrysler just skimped. My bad Chrysler my bad.
Unread 11-24-2013, 05:20 PM   #9
rickcricket
I can't even run mine on hot or I will show up to work with some serious swamp @ss.
Unread 11-24-2013, 06:01 PM   #10
Jaspah
No, no. They still skimped. The wiring is fairly shoddy-- I'd recommend buying aftermarket heating pads and forgo the original Chrysler wiring altogether. There's a good write up on some Dorman replacement seat heaters on these forums somewhere.
Jaspah is offline   Reply With Quote Quick reply to this message
Unread 11-25-2013, 10:47 AM   #11
BlueJc
Location: UK,Great Britain, 51st state of USA, Northumberland
I cut the broken wire out then re soldered it back together. works fine now.
You will probably find the broken wire on the side closest the door. Mine had a brown burn mark where the wire had failed.
2002 2.7 CRD Jeep grand Cherokee Ltd. You can take a horse to water but a pencil must be lead!
BlueJc is offline   Reply With Quote Quick reply to this message
Unread 11-30-2013, 06:28 PM   #12
MuddyWJ
Okay so I looked under my seat at the wiring harnesses and can't see any obvious burn marks. Does anyone know of a diagram of the wiring? Don't want to tear into all of them. The motors are labeled but nothing else
Unread 12-01-2013, 04:09 AM   #13
MadderThanMax
Doesn't really work
Not farting hard enough then are you....
Unread 12-01-2013, 07:19 AM   #14
rickcricket
Did you take the leather off the seat cushion? It's not just under the seats! You actually need to remove the leather seat bottom to see the heat pad.
Unread 12-01-2013, 07:20 AM   #15
ejeep00
2003 WJ
My butts cold too ughhhhh
ejeep00 is offline   Reply With Quote Quick reply to this message
