Multiple codes, need help please. - JeepForum.com
post #1 of 9 Old 11-03-2011, 11:45 AM Thread Starter
jsaunsnp
I have a 2003 Grand Cherokee with the 4.0. About a month ago it started rough idling and would stutter at highway speeds. I replaces the coil rail and plugs and that seemed to fix it for about a week. It started doing it again, the check engine light came on, after shutting it off and starting it up again it stopped and the light was out. Today it started doing it again but it seems worse. At one point while driving the light started flashing so I got home and now need to figure out what to do. The codes it is showing are P0122, P0107, P0205, P0300, P0303, P0442, P0305, P0456.
Any help or suggestions would be greatly appreciated.
jsaunsnp is offline
post #2 of 9 Old 11-03-2011, 12:17 PM
Thomahawk
http://www.wjjeeps.com/faultcodes.htm
Start here....
Sent from my Iphone4
Buildthread
Thomahawk is offline
post #3 of 9 Old 11-03-2011, 12:19 PM
Tezzating
P0107 - MAP sensor voltage low
P0122 - Throttle Position Sensor voltage low
P0205 - Injector fault #5
P0300 - Multiple random misfires
P0303 - Misfire cylinder #3
P0305 - Misfire cylinder #5
P0422 - Vapor leak (small) from EVAP detected
P0456 - EVAP leak (small) detected
IMO, verify battery charge level (over 12V) and condition, clean the terminals and posts (replace the terminals if necessary), clean the ground points (passengers inner fender, engine block to firewall), clean the terminal and post on the alternator, get the alt tested. Clean up the fuses in the PDC next to the battery too.
Wonky power will cause all sorts of problems, and the low voltage warnings from multiple sensors makes me think power problem. Misfires and generally bad running are symptoms of bad sensor inputs.
Those two EVAP codes are typically cause by fitting a non-stock gas cap, a busted stock gas cap, or a stock cap not fitted properly. Try removing the cap with the engine off, then snugging it back down again. Clear the codes and see if that helps.
Good luck
Tezzating is offline
post #4 of 9 Old 11-03-2011, 12:32 PM Thread Starter
jsaunsnp
Thanks I will start with the electrical power supply.
As far as the evap codes I do remember my wife coming home after getting fuel about a week ago and the fuel door was shut but the cap was still hanging down.
jsaunsnp is offline
post #5 of 9 Old 11-03-2011, 01:12 PM
MeanGreenZJ
Check the wiring harness behind the valve cover. Some times the valve cover stud rubs a hole into the wiring harness and starts shorting things out.
MeanGreenZJ is offline
post #6 of 9 Old 11-03-2011, 01:18 PM Thread Starter
jsaunsnp
would that be the one that runs to the map sensor?
Also as a side note, when I replaced the coil rail and plugs I put in Bosch platinum + 4's after reading through the forums I take it I should switch those back out work the standard champions?
jsaunsnp is offline
post #7 of 9 Old 11-03-2011, 05:59 PM
MeanGreenZJ
It's the one that is about an inch thick with the coil harness coming out of it.
post #8 of 9 Old 11-03-2011, 06:18 PM Thread Starter
jsaunsnp
Gotcha,
Well I cleaned and inspected the battery, grounds and relays. The negative side confection seemed a little loose so I made sure I tightened them both down tight.
I also pulled the coil rail off and replaced the new plugs I had put in with the oe champions.
I inspected the wiring harness, there was some wear on the jacket but not all the way through. So I wrapped that and hopefully fit it off the bolt. After all that and erasing the codes I drove it about 75 miles and it seems to be running good.
hopefully that will take care of it. Time will tell.
Thanks to everyone for the fast responses and help.
I appreciate it,
John
jsaunsnp is offline
post #9 of 9 Old 11-03-2011, 08:45 PM
MeanGreenZJ
Bosch in a Chrysler? Shame on you LOL
Multiple OEM Codes - P0202 to P0208 dlong63 WJ Grand Cherokee Forum 1 07-22-2011 06:45 AM
Got multiple questions ... newb PaulRevere WJ Grand Cherokee Forum 13 12-17-2010 01:01 PM
My multiple oil leaks PICS themow WJ Grand Cherokee Forum 1 12-08-2010 05:35 AM
Just bought a Jeep Grand Cherokee which is throwing multiple codes, 01grandcherokee WJ Grand Cherokee Forum 8 10-29-2010 01:37 PM
Multiple Failures, need advice... Duck Vader WJ Grand Cherokee Forum 13 07-21-2010 09:55 AM
