moog ss won't fit :s - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > moog ss won't fit :s
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 05-24-2013, 04:17 PM   #1
SierraRipper
Decided to install my steering stabilizer while i'm waiting on the lift kit to arrive. I took off the old one only to find out that the moog wont fit. Correct me if im wrong, i tried putting the blue boot towards the wheel? Right? the clamp is too small do i have to buy some conversion kit? :s
Moog next to the mounting bracket
Moog next to oem ss
SierraRipper is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 04:20 PM   #2
jpat30
Not sure about the Moog, but with my Rancho, I had to ream out the opening with a drill to fit the factory bolt and it doesnt matter what end the boot goes on.
-Carpe Diem Phil 1:20
jpat30 is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 04:22 PM   #3
SierraRipper
Im stupid, the end doesnt even go in the bracket, it goes on top lmao sorry guus i freaked out hahaha
Unread 05-24-2013, 04:23 PM   #4
jpat30
Its awright......It happens. Have a great weekend.
Unread 05-24-2013, 05:33 PM   #5
SierraRipper
Thanks alot, you too! Hope its on right! Lol
Unread 05-24-2013, 06:19 PM   #6
madslynge87
Haha ! nice one ! Looks beefy have one on my way as well.
madslynge87 is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 06:23 PM   #7
jeep04
I think you should move the blue boot side to the other side of the tie rod so its not at such an angle.... cause that just doesn't look right to me but I could be wrong
04 Jeep wj Limited 4.7 <> 6.5" Iron Rock long arms front & Adjustable lowers on rear <> Bilstein 5100's <> 285/70r17 Goodyear Duratracs <> M/T black classic lock wheels <> Addco swaybars <> Superchips 3875 <> Magnaflow Stainless exhaust <> 2 Kicker comp 12's <> Kenwood head unit.
jeep04 is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 06:34 PM   #8
SierraRipper
So should i just switch the end piece to the bottom part of the bracket? o_0 a picture would help! :]
Unread 05-24-2013, 06:58 PM   #9
jeep04
..I would think so or put it up on the drag link if you want it out of the way.... here is a link from another forum with good pics
http://www.jeepsunlimited.com/forums...d.php?t=409839
Unread 05-24-2013, 07:25 PM   #10
MuddyWJ
Your wheel side is too far up. If you cycle the steering wheel you'll find the SS moves closer to the axle. Loosen the tire side then turn the steering wheel all the way to the right. Move the SS just so it doesn't hit axle.
MuddyWJ is offline   Reply With Quote Quick reply to this message
