Missing radiator fan? 00 4.0 2wd. There is only electrical fan. Should mechanical fa - JeepForum.com
post #1 of 3 Old 03-22-2015, 08:43 PM Thread Starter
car5car
2002 M-38
Missing radiator fan? 00 4.0 2wd. There is only electrical fan. Should mechanical fan be there? Does your Jeep have mechanical and electrical fans?
Thanks.
01 XJ 2wd 4.0
car5car is offline
post #2 of 3 Old 03-22-2015, 09:39 PM
Highschool_WJ
Thanks.
Perfectly normal for it to not be there, I believe the mechanical fan was part of the tow prep group, so if have the tow package it likely left the factory with no towing package or prep group and had the tow package installed as an option by the dealer that received it and the actual mopar tow package they put on them included everything but the mechaincal fan as the fan was only part of the tow prep group.
http://wjjeeps.com/trailer.htm
In other words it's peferctly normal to not have a mechaincal fan if you don't have the tow prep group as a factory option.
,,,soooo I graduated in 2013...
Highschool_WJ is offline
post #3 of 3 Old 03-23-2015, 12:14 AM
losttech
You can add one super easy just screws on the front of the water pump with a 36mm nut reverse thread.
I like having them both as a backup since the E-fan can be unreliable.
losttech is online now
