The millionth diff fluid thread - JeepForum.com
post #1 of 8 Old 12-18-2013, 12:09 PM Thread Starter
mxjosh
Ok guys, before I get lit up I've searched through a ton of threads and looked all over wjjeeps.com....
I have a 2004 WJ 4.7HO with Quadra-Trac II, looking to change my diff fluids soon. Correct me if I am wrong, but looks like I have a D30 front axle, D44 rear axle, and NV-247 transfer case. I plan on running 75W-140 synthetic in both, but I haven't been able to tell if I have a rear LSD that would require a friction modifier. Anyone know?
Thanks for the help!
mxjosh is offline
post #2 of 8 Old 12-18-2013, 12:22 PM
robbie1003
this was a question I asked my dealer when I was looking to change mine.
if you get "normal" diff oil or buy genuine jeep (probably PETRONAS now) you will need the modifier for the system to function correctly but (this was suggested by my jeep dealer) there are diff oils specifically for lsd diffs which already contain the modifiers, a little more expensive than normal diff oil but you don't need to buy the modifier.
robbie1003 is offline
post #3 of 8 Old 12-18-2013, 12:29 PM Thread Starter
mxjosh
I don't think you understood my question. Friction modifiers/ oils with friction modifiers included are required only on LSD diff's. I'm asking if my qudratrac II rea D44 is LSD or not?
mxjosh is offline
post #4 of 8 Old 12-18-2013, 12:30 PM
alfaitalia
Op has QT2. Quadratrac 2 needs no friction modifier as it has open diffs. Only quadradrive needs its because it has varilock diffs.
Sent from the Dark Side using only the Force.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #5 of 8 Old 12-18-2013, 12:44 PM
Thomahawk
Originally Posted by alfaitalia
op has qt2. Quadratrac 2 needs no friction modifier as it has open diffs. Only quadradrive needs its because it has varilock diffs. Sent from the dark side using only the force.
^^^x2
Buildthread
Thomahawk is offline
post #6 of 8 Old 12-18-2013, 01:03 PM
blackcar87
1994 XJ Cherokee
Jack the rear up, spin the wheels. If they spin opposite of each other=open rear. If they spin the same direction =LSD needs modifier.
1994 Cherokee country, 3 inch aal, 17x7 Jeep Libery wheels, 245/75/17' BFG's, yakima rack
2004 Grand Cherokee Freedom Edition 4.7 HO ebc dimpled/slotted rotors, green stuff pads, Bilstein shocks
"Do you know about Tyler Durden?"
blackcar87 is offline
post #7 of 8 Old 12-18-2013, 01:12 PM
blackcar87
1994 XJ Cherokee
Also the stamped tag bolted to the rear end cover says 75w 140 SYN FRIC MOD 4 OZ if it has varilocks.
post #8 of 8 Old 12-18-2013, 06:05 PM Thread Starter
mxjosh
Thanks guys, answered what I needed.
mxjosh is offline
