Memory Seat Install... Is it Possible?. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Memory Seat Install... Is it Possible?.
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 09-28-2010, 02:43 AM   #1
blazepsi
Is it possible to install a memory seat in a Laredo? like the picture here: http://www.wjjeeps.com/2004_limited_22.jpg
My wife sometimes uses my jeep and i hate it when i always have to adjust everything to the way i wanted to. The seats are Powered by the way...thnx for the help..
blazepsi is offline   Reply With Quote
Unread 09-28-2010, 06:41 AM   #2
JunkJeep228
1994 XJ Cherokee
I'm sure if you had enough money, the ones that come factory like that have that feature tied into the ecu, It works through the key or the remote, which would mean changing out your entire ecm, security system, and possibly your ignition if its tied into the security chip key. The ecu might not be compatable with your engine, so you 'd prob have to set up a stand alone system, finding a donor would be near impossible. I dont know if they ever installed that in grand cherokee's, i'm going off of what i know they did in cadilacs and buicks, but if you really want it and they put it in newer ones i think you'd be further ahead to trade in yours for one of those.
"Wheel it, Break it, Build it better." Words to live by.
JunkJeep228 is offline   Reply With Quote
Unread 09-28-2010, 06:45 AM   #3
JunkJeep228
1994 XJ Cherokee
Sorry, just looked at the pic closer, if it is a totaly isolated system with a button on the door than its totaly possible you'd just have to find the parts and pieces and switch them out. On the high end gm's when you press the button on your remote or put your key in the ignition thats what makes everything move.
Unread 09-28-2010, 07:07 AM   #4
ezflip
The memory seats are controlled by the bcm (body control module) which is basically thr brain for everything electronic outside of the engine (power control module) Theoretically, you could swap your bcm for one that had that feature, but you would be throwing a lot of money on something that is rather silly imo. Between the seats themselves, the bcm, the buttons on the door panel, the wiring for all of that, and having your keys reprogrammed with your new bcm and your key fobs programmed to control the seat memory, thats a whole lot of time and money when it takes 2 minutes to put the seat back where you like it....or just dont let others to drive your jeep and its not a problem
2002 Overland - 4.7 HO, "Select-Drive", 4" RC long arms, TAG front winch bumper, 32" BFG KM's
Build Thread KCCO
ezflip is offline   Reply With Quote
Unread 09-28-2010, 03:42 PM   #5
straty1987
can install the seat but the memory feature will not work without a bunch of work
straty1987 is offline   Reply With Quote
Unread 09-28-2010, 04:01 PM   #6
tsconver
2003 WJ
fist thing to do is to remove the door card and see if the wiring is there. If it is wired the BCM will control it, they did not have different BCMs for differnet trim levels.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
My Build Thread
A few goodies
http://s257.photobucket.com/albums/h...umb55839/jeep/
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
http://www.zrxoa.org/
2006 Red Liberty
Wife's ride, pretty stock
http://i257.photobucket.com/albums/h...mage0008-1.jpg
http://www.cnc4x4.org/
http://www.treadlightly.org/
tsconver is offline   Reply With Quote
Unread 09-28-2010, 06:03 PM   #7
BransJeep
mine works..i swapped the leather seats into my 00' laredo got the limited panels and the wiring harness from the donor limited and it works.. the harness is removable from the little rubber boot in between the door and body relatively easy. just depends if you think its worth the money, but on the other hand i did it almost for free so i went for it. you will also notice that once you install the seat with memory a new option will be in the overhead console that says.."memory linked to remotes?"
-Brandon
4.0, 42re, 242
4.5 inch lift, front Ironman 4x4 adjustable CA's
RB1 and full J&L audio setup
Rola roof rack
BransJeep is offline   Reply With Quote
Unread 09-28-2010, 06:16 PM   #8
Falkon
There's a specific module for the Memory Seats as per WJ Jeeps...
Jeep Grand Cherokee WJ - Electronic Control Modules
Falkon is offline   Reply With Quote
Unread 09-28-2010, 06:17 PM   #9
BransJeep
the module also controls the heat feature
-Brandon
4.0, 42re, 242
Rola roof rack
Unread 11-23-2011, 04:35 PM   #10
twoweelz5
So I put the ten way heated seats in my 2001 JGC laredo but I have not been able to get the heat function to work.
twoweelz5 is offline   Reply With Quote
