Max tire size question - JeepForum.com
post #1 of 17 Old 08-14-2013, 12:05 AM Thread Starter
elcorvino
2003 WJ
I always see questions about max tire sizes and then people post that chart. Is that chart based on people who want to run the biggest tires at X height with no trimming? Is there really a big difference of the size tires one could fit on say a 2 or 2.5" lift if they had no intentions of ever diverging from highway driving VS hard wheeling?
Sorry if its a stupid question - didn't want to hijack a thread for this.
elcorvino is offline
post #2 of 17 Old 08-14-2013, 12:48 AM
SierraRipper
Its based on recommended max tire size at (x) amount of lift for best performance offroad depending if you want to trim nothing, plastic, or fenders. You dont want to hit the trails with a tire hugging your fenders/wheel well
SierraRipper is offline
post #3 of 17 Old 08-14-2013, 01:18 AM Thread Starter
elcorvino
2003 WJ
So for instance... You can fit a 31" tire at 2" of lift with no trimming if wheeling; what could go in there for a hwy vehicle?
You can fit a 32" tire at 3" of lift with no trimming if wheeling; what would fit on a hwy vehicle?
post #4 of 17 Old 08-14-2013, 02:01 AM
Thomahawk
I couldnt fit a 31" with my 2-2.5" lift,
It depends on thread depth, different model tires in same size, ex 255/70/17 is not the same diameter, they Are all a little different, you may have to check the excact spec for your tire of choice.
Buildthread
Thomahawk is offline
post #5 of 17 Old 08-14-2013, 02:12 AM
SierraRipper
Totally agree
If you want to stuff the wheel well, have a tire shop give you some options.
post #6 of 17 Old 08-14-2013, 02:26 AM Thread Starter
elcorvino
2003 WJ
Thanks guys - didn't even realize that. I though a 31" was a 31" And tread was included in that measurement.
post #7 of 17 Old 08-14-2013, 05:22 AM
Thomahawk
I didnt either, before i got my GG AT2 255/70/17 and thought they where 31's, couldnt understand why they rubbed everywhere.
Had to do some trimming, but deff worth it, when you first have cut in your Jeep, everything feels so much easier, but getting there aint easy.
Order tires, and find the dremmel guys, it will look soo much better
Buildthread
post #8 of 17 Old 08-14-2013, 07:48 AM
grussell
I have 245/65/16's and they rubbed the left fender liner.
2001 GC Laredo 4.0 4x4 - Black l 2001 GC Laredo 4.0 4x4 - Silver
grussell is offline
post #9 of 17 Old 08-14-2013, 07:53 AM
ChrisHager
Administrator
ChrisHager's Avatar
There's really no 'right' answer. It's hard to tell what size tire will fit when you take into account any sagging, extra weight on the vehicle, wheel backspacing, etc. My 245/75R16 fit with no rub on my OME HD lift. Once I bumped the wheels out 1.5", I had to trim some of the front fascia.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #10 of 17 Old 08-14-2013, 11:30 AM Thread Starter
elcorvino
2003 WJ
Seems like a crap shoot honestly. Buy what worked for someone else and hope for the best. Lol
post #11 of 17 Old 08-14-2013, 12:19 PM
ChrisHager
Administrator
ChrisHager's Avatar
Pretty much. The suggestions on here are excellent guidelines but I wouldn't ever say 'this WILL work 100% with no trimming'.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #12 of 17 Old 08-15-2013, 12:55 AM
timbotrog
2014 JK Wrangler
I have a 2" lift, (Bilstein 5100 & Dobinsons coils) running 245/70/17 Yokohama Geolander AT-S on JK MOAB rims. No rubbing at all anywhere during hard wheeling and is the largest size you will fit into the spare wheel well without having the floor sit up on you.
Thats effectively a 31" tyre in diameter but only about 10" wide. I can easily fit my hand between the tyre and shock body.
timbotrog is offline
post #13 of 17 Old 08-15-2013, 03:13 PM
Crash4x4
One thing that nobody mentions is the loss of torque. The bigger the tire you go, the less torque you will retain at wheels. I've noticed a huge difference and would of gotten 30" tires vs the 31" that I have.
Crash4x4 is offline
post #14 of 17 Old 08-15-2013, 03:14 PM
ChrisHager
Administrator
ChrisHager's Avatar
That's where re-gearing comes into play... Typically people don't bother in regards to the WJ until 32"/33" and up.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #15 of 17 Old 08-15-2013, 04:33 PM
Thomahawk
I have noticed this myself, only from 30-31's is a big difference, lower mpg, loss off torque, and need to down shift/hold liwer gear at steep hiils.
I might start Get used to it by now, but firstcthing i thought was REGEAR, ha F...
Anyway, no Way back
Buildthread
