Max number of 130 watt lights my alternator can handle? - JeepForum.com
post #1 of 17 Old 04-27-2010, 09:42 PM Thread Starter
gunnerscherlin
2005 WK
I have a wj and have 4 130 watt lights on it already but i want to put on 4 more pencil beam lights from hella but i dont know if my alternator can handle the draw. Does anyone have advice or know if it can hold up?
gunnerscherlin is offline
post #2 of 17 Old 04-27-2010, 10:07 PM
robd2003
depends how many amps the lights draw, and if you have everything running i.e. all "8 lights" or you can switch between which ones are on and off
robd2003 is offline
post #3 of 17 Old 04-27-2010, 10:10 PM
ras2001wj
ras2001wj's Avatar
Why would you possibly need so much light?
And a few corrections to your profile:
You have a 42re transmission, the NP242 is your transfer case(not PN242),
Your front axle is a Dana 30
Your rear axle is either a Dana 35 (most probable) or a Dana 44a (with the towing package), the dana 42 never existed
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
ras2001wj is offline
post #4 of 17 Old 04-27-2010, 10:13 PM Thread Starter
gunnerscherlin
2005 WK
I am planning on using all 8 of them and sorry ras2001wj i didnt feel like lookin up the info lol but thanks dude
2005 WK Limited HEMI , 2 Hella 4000 HID SPOT, Alpine Stereo
Magnaflow Exhaust
Future Mods: OME HD, 285/70/17 Goodyear duratracs, and CAI
post #5 of 17 Old 04-27-2010, 10:30 PM
yozsi
well figure that you are operatating at about 13.5-14.5 volts when the car is running. so that is 8.97 to 9.63 amps per lamp at those voltages.
yozsi is offline
post #6 of 17 Old 04-27-2010, 10:49 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
If you're crawling on a trail, with all that and your stock lights running. You'll be drawing down the battery as your alt will never keep up.
Work on light placement and aiming. I can't think of any reason to have that many pencil beams and floods/fogs on at once.
ratmonkey is offline
post #7 of 17 Old 04-27-2010, 10:52 PM
JesseOR
He wants to cook the deer before he hits it! or dry up all the mud so its not as slick!
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #8 of 17 Old 04-27-2010, 11:41 PM
straty1987
right now you have 4 lights
130 watt * 4= 520 watt
50watt / 12v = 43.33 amps
want to
130 watt * 8= 1040 watt
50watt / 12v = 86.67 amps
the stock WJ alternator is 136 amps i believe
might want to consider your needs and build around that. dont want to kill your battery or start a fire. like mix in fog and driver lights so you can get distance and better lights around you.
if your going to do 4 130 watts light on the roof consider doing 4 55watt lights. 2 driver lights (pencil beam) for distance and 2 fog lights to get a better view on your sides.
if you have any pics i like to see the 4 130 lights your running.
straty1987 is offline
post #9 of 17 Old 04-28-2010, 07:25 AM Thread Starter
gunnerscherlin
2005 WK
Well i already have 4 driving lights on the grille but thinking about adding the 4 up top and ill get pictures up soon
Magnaflow Exhaust
post #10 of 17 Old 04-28-2010, 07:28 AM
xJoshxx
2012 WK
Tip get the BIGGEST battery you can get to fit in your Battery Tray.
i have 6x130W KC Long range lights.
if i turn them on at idle you can hear the jeep idle up for moar power to the battery and watch the battery gauge move a little unless your driving.
i have a 1200cca battery
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #11 of 17 Old 04-28-2010, 07:30 AM
SpeedJeep
SpeedJeep's Avatar
You can get an eye exam and prescription lenses @ walmart for about $150.
SpeedJeep is offline
post #12 of 17 Old 04-28-2010, 07:38 AM
xJoshxx
2012 WK
already did that haha but i live in the sticks with plenty o forest blind curves that deer like to setup traps.
2011 WK2 ORA2 sold
xJoshxx is offline
post #13 of 17 Old 04-28-2010, 03:22 PM Thread Starter
gunnerscherlin
2005 WK
I live in Wyoming so highway driving sucks at night cause the damn deer go out of their way to get hit so light is good
Magnaflow Exhaust
post #14 of 17 Old 04-28-2010, 08:12 PM
comptiger5000
The key is using the right lights (beam pattern) and getting them aimed well, as well as making sure your headlights are working well. You'll get more from your headlights + 2 lights that put the light where you need it than you will from 10 lights that put it somewhere else.
comptiger5000 is offline
post #15 of 17 Old 04-28-2010, 10:09 PM Thread Starter
gunnerscherlin
2005 WK
Amen to that
True right now i have the 2 middle ones pointed barely out but mostly forward and the outside 2 are pointed inward so the make a big X so they cross far away but also give a lot of light forward too.
Magnaflow Exhaust
alternator , hella , lights , watts
Stock part number for a 98 5.9 alternator 150 amp? bjl95mustang ZJ Grand Cherokee Forum 6 05-06-2010 06:32 AM
does the chassis number is the same as the motor number for each car ? amh WK Grand Cherokee & XK Commander Forum 1 01-05-2010 12:12 PM
Need rear tailgate handle part number subliminal ZJ Grand Cherokee Forum 0 05-10-2009 01:01 PM
can the stock harness handle 100 watt lights? rdrbssr11 ZJ Grand Cherokee Forum 7 09-18-2006 02:12 PM
Can it handle it? NickF829 ZJ Grand Cherokee Forum 5 08-29-2004 12:48 PM
