Master Brake Cylinder going bad? - JeepForum.com
post #1 of 15 Old 12-13-2013, 07:45 PM Thread Starter
Jeep01AH
Wj Master Brake Cylinder going bad?
I've done some reading and I think I've got it narrowed down, but I just want some input from everyone else.
Lately the Jeep has been sitting outside all night in sub zero temperatures for days because I'm keeping it at school. When I go to start it to go to work, there is no pressure behind the brake pedal. I would pump it for a minute and it would come back. Today when I was driving home, I didn't use the pedal for a while because I was on the highway for over two hours. When I finally came to a stop light, I had no pressure and wasn't able to stop. Luckily the light turned just before I went flying through. This is the first time this has happened while driving. I have no leaks and my fluid is full. Is this the master cylinder going out on me?
Any help is appreciated!
| 2001 WJ - 4" Lift - Locked - 33s | My Build Thread:
| ΜΟΛΩΝ ΛΑΒΕ |
4 Wheel To Heal - Serving our wounded and disabled veterans -
- 4W2H
Jeep01AH is offline
post #2 of 15 Old 12-13-2013, 07:54 PM
WiLieR
If you can pump the pedal and it will build pressure and work then the master cylinder is the one that is extremely likely the culprit. If it were my WJ I would replace the MC and go from there.
Check you soft hoses as well. Most people never think to replace those and they are 9-14 years old by now and most likely needing to be replaced.
99 WJ Laredo - Mine once again!
WiLieR is offline
post #3 of 15 Old 12-13-2013, 07:58 PM Thread Starter
Jeep01AH
Thanks for the reply!
I am looking into replacing the hoses with braided steel lines in the near future. I suspected the master cylinder though. Thanks for the help.
| ΜΟΛΩΝ ΛΑΒΕ |
- 4W2H
Jeep01AH is offline
post #4 of 15 Old 12-13-2013, 09:07 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Get it changed ASAP.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #5 of 15 Old 12-14-2013, 12:47 PM
MadderThanMax
+1 Been there done that....
MadderThanMax is offline
post #6 of 15 Old 12-20-2013, 09:34 PM Thread Starter
Jeep01AH
I had a shop change out the master cylinder and I'm gonna assume they bled the brakes properly, but now I have a really low brake pedal. The brakes will not engage until about 2 inches from the floor. Does anybody have any ideas what could be causing this? Nothing is leaking and I have enough fluid. There is one pretty rusted spot on the hard line traveling to the rear axle. Could air be seeping in this way?
| ΜΟΛΩΝ ΛΑΒΕ |
- 4W2H
Jeep01AH is offline
post #7 of 15 Old 12-21-2013, 04:33 AM
MadderThanMax
Brake Servo may not be operating as effectively as it should.. this would cause a drop in pedal..If it has a hose connection to it, with the engine off pull the hose out, It should *pop* if working properly if it hisses then its a fail and needs replaced...
post #8 of 15 Old 12-21-2013, 05:20 AM
doityourselfMM
doityourselfMM's Avatar
What makes you assume that they bled the brakes correctly? There is a procedure for bleeding the master cylinder on the bench, prior to installation in the vehicle. And there is also the ABS system and bleeding procedure.
Not saying the shop didn't do the job correctly, just saying I wouldn't assume they did, if the pedal only begins to engage the brakes close to the floor.
Don't ignore that rear brake line. That rusted line is a common problem on WJs. I actually had that line explode on my 99. The pedal went to the floor and brake fluid squirted everywhere. If that line ruptures, you will have no brakes.
doityourselfMM is offline
post #9 of 15 Old 12-21-2013, 11:43 AM Thread Starter
Jeep01AH
I pulled the hose off and it popped followed by a short high pitched hiss. I'm not sure if the failure hiss should be drawn out or short. What do you think about this?
| ΜΟΛΩΝ ΛΑΒΕ |
- 4W2H
Jeep01AH is offline
post #10 of 15 Old 12-21-2013, 12:43 PM
MadderThanMax
If it popped, and its a loud, clear *pop* by the way then I'd say that your ok. Its when you pull the hose and it just hisses, then worry..
The *pop* is created by a perfect vacuum in the servo - The Hiss indicates a pin hole or tear in the diaphragm inside the servo. The latter would happen immediate the hose was removed.. so I'd say that your good to go and maybe looking at rebleeding the brakes...
post #11 of 15 Old 12-21-2013, 08:46 PM Thread Starter
Jeep01AH
So after eliminating the booster today, I can only believe that there is air in the lines still. I will be going by the shop in Monday to ask them about their bleeding procedures. So far my questions are 1) did the bench bleed the master before they installed it 2) what was the wheel position order they bled them 3) did they bleed the abs system with an obd2 tool? Can anyone think of any other questions I should ask? I'm also looking into getting that hard line replaced. It looks terribly brittle.
| ΜΟΛΩΝ ΛΑΒΕ |
- 4W2H
Jeep01AH is offline
post #12 of 15 Old 12-22-2013, 03:08 AM
MadderThanMax
That last question is a bit ambiguous "An OBD2 Tool" you're liable to get that look of horns on your head... An OBD2 tool only reads/resets the codes nothing else...
post #13 of 15 Old 12-22-2013, 03:10 AM
MadderThanMax
What happens when you pump the pedal?? does it get firmer?
post #14 of 15 Old 12-22-2013, 04:37 AM
michiganmaveric
Got Beer?
2011 JK Wrangler
The bleed tool is an OBD3, which cost thousands and they probably do not have.
Lifetime member #13
post #15 of 15 Old 12-22-2013, 10:08 AM Thread Starter
Jeep01AH
Thanks for the correction. I will probably have to go to the dealer for the OBD3 then. Also, when I pump the pedal with the car on, it does not get any firmer. When I pump the pedal with the car off, it hardens up like it should.
| ΜΟΛΩΝ ΛΑΒΕ |
- 4W2H
Jeep01AH is offline
