Map sensor connector - JeepForum.com
post #1 of 8 Old 10-06-2013, 07:48 PM Thread Starter
MichaelS75
The connector to the map sensor on my 4.7 is totally broken and the wires don't seem to be connecting well throwing a p0121 code and causing my wj to stall. I taped it up but that only fixed it for a day or two. Should I try to find a new connector somewhere or can I just bypass it and wire it straight to the sensor?
MichaelS75 is offline
post #2 of 8 Old 10-06-2013, 08:50 PM
gold3n_8oy
Hi. Can you show me pictures or the exact location of this map sensor?I have map sensor codes on and off..plan to clean it first before replacing it. Thank you.
gold3n_8oy is offline
post #3 of 8 Old 10-06-2013, 09:04 PM Thread Starter
MichaelS75
These are crappy pics but basically it's attached to the front of the intake manifold behind the alternator. You can access it much easier if you take off the air intake box
post #4 of 8 Old 10-06-2013, 09:34 PM
gold3n_8oy
Pics not clear but i will give it a try. It is not mounted at the back of the alternator does it? Is it hard to remove? Thanks again
post #5 of 8 Old 10-07-2013, 07:58 AM Thread Starter
MichaelS75
No it's behind the alternator attached to the intake manifold. I used a 20 or 25 torx bit and a 6 inch extension and it was still tough to get it out. Just look in between the alt and the AC unit and you'll see it attached
post #6 of 8 Old 10-07-2013, 10:27 AM
gold3n_8oy
Ok.i saw it. But i gonna forget to do it myself as it is hard..gonna ask a mechanic to do it.thanks
post #7 of 8 Old 10-07-2013, 04:33 PM
bigred1821
I had a similar problem in the spring. I replaced the sensor but broke the wiring connector. The new sensor didn't seem to work. Eventually I found that the rubber elbow that comes out of the back of the map sensor and elbows into the throttle body had a small crack in it, causing the code and for the truck to stall out if I wasn't on the gas. I have the 4.0 but it wouldn't hurt to check this because I overlooked it and it was a really easy fix.
bigred1821 is offline
post #8 of 8 Old 10-08-2013, 07:41 PM
gold3n_8oy
Will check it.thanks
