MAMBA MR1X fit on wj? - JeepForum.com
post #1 of 17 Old 03-11-2014, 01:42 PM Thread Starter
tauruspt2
Hello everyone I was looking at wheels today for my wj.
I plan on getting a 2" lift and some new tires.
I was looking at the black MAMBA MR1x wheels:
http://www.tirerack.com/wheels/Wheel...Standard+Model
I chatted with their customer service and they said they wont fit my wj?
Is this true?
WJ Limited 2" IRO Lift, Bilsteins, MOOG steering stabilizer, Mamba M13x rims
Cooper Discover AT's
tauruspt2 is offline
post #2 of 17 Old 03-11-2014, 01:53 PM
1999wjlimited
I googled them and they come in 2 different bolt patterns. 5x4.5 and 5x5 you just have to make sure you get the ones that are 5x5.
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is offline
post #3 of 17 Old 03-11-2014, 05:57 PM Thread Starter
tauruspt2
Thanks, hoping to find these or black Moabs for cheaper.
post #4 of 17 Old 03-11-2014, 06:49 PM
braddf
how much are they?
Build thread: http://bit.ly/1puFzZm
Stock rims for sale: http://bit.ly/1kMw7k5
braddf is offline
post #5 of 17 Old 03-11-2014, 07:09 PM
jUAN_doLLaZ
and unless u lift it, your gonna poke out like....
At 2" with 245/75/16 some bumper trimming is necessary, not the actual edge of the bumper that you'd see but the interior that the fender liner tucks into, relative to the scrub of the tire. If you opt to lift without the track bar you will rub more on one side than the other. further rubbing will occur if you get longer control arms too. Fog lights are clear of the tire scrub by about half an inch.
jUAN_doLLaZ is offline
post #6 of 17 Old 03-11-2014, 07:13 PM
jUAN_doLLaZ
Is this true?
Moabs will not fit, there is a member on here who made them fit using a 1.25inch spacer/adapter. Some will advice against that. the Mamba's will fit buttttt you need to make sure you get the right bolt pattern and offset. i got them from CARID and they said it would not fit, but that is because of the offset and subsequent bumper trimming you'd need un-lifted.
post #7 of 17 Old 03-11-2014, 07:20 PM
jUAN_doLLaZ
post #8 of 17 Old 03-11-2014, 08:56 PM Thread Starter
tauruspt2
Originally Posted by braddf View Post
how much are they?
Around $120 each at 16 x 8
post #9 of 17 Old 03-11-2014, 08:58 PM Thread Starter
tauruspt2
What's offset?
Would 245/70/16 rub?
post #10 of 17 Old 03-11-2014, 09:58 PM
jUAN_doLLaZ
+6 offset
if i were to do it again id go 255/70/16, but thats splitting hairs
post #11 of 17 Old 03-12-2014, 01:41 PM Thread Starter
tauruspt2
+6 offset
Will 245/70/16 rub?
post #12 of 17 Old 03-12-2014, 01:43 PM
pmdowd6
Moabs won't fit? Not sure where you got that information from
pmdowd6 is offline
post #13 of 17 Old 03-13-2014, 10:30 AM
jUAN_doLLaZ
i meant tj moabs as in lower offset, actual concave face that the mambas replicate which is usually otherwise found in 4.5x5. regular moabs fit, sure, but imo huge difference in appearance
post #14 of 17 Old 03-14-2014, 09:49 AM
WJ_allday04
im actually looking at these rims right now...can you post a pic a little more zoomed out so there's more of the jeep?
2004 WJ 4.7 - 7in lift
Rustys Long Arms//Rustys f+r springs//Rustys crossmember
CSL RLCA//Poly D30 bushings//IRO A arm
Skyjacker Nitro's//JKS trackbar//242HD+IRO SYE
WJ_allday04 is offline
post #15 of 17 Old 03-16-2014, 04:45 PM
jUAN_doLLaZ
