Major Issues With 99 WJ Limited - Page 3 - JeepForum.com
post #31 of 34 Old 09-14-2013, 06:49 PM
narnwv
narnwv's Avatar
Originally Posted by 99WJLimited View Post
So I replaced my TPS and the input and output speed sensors and also the pressure sensor in my tans and so far no codes. To my surprise everything seems to be functioning better than the day I bought the WJ with shifting smoothness. at this point all seems good and will be waiting to see if I throw any new CEL codes. Unfortunately I cant tell you which one seemed to fix the issues I was having since I replaced all them in one shot. I pulled all the sensors from a 2000 Durango which had the same trans in it at a local Pick and Pull Junk yard. Go figure it was the first time there that they only had models before the WJ and the 45RFE was introduced in the first year of WJ's (99). I am hoping that I just got lucky today. I will keep an eye on it and keep updating if there is any changes in the near future. Thank you to everyone who replied to try and help me correct this issue!
Any updates? Does your trans still run well? I have the same P1728 code on mine, which is a replacement transmisison (has had the code since we put it in).
~Aaron
narnwv is offline
post #32 of 34 Old 11-16-2013, 03:37 PM
link375
I would like an update on this as well, I just got the P1728 code on my transmission
the solenoid pack, input and output speed sensors, transmission filters, fluid and TCM have all been replaced
I really don't want to have to replace the transmission
link375 is offline
post #33 of 34 Old 11-23-2013, 08:23 PM
link375
well i was able to get rid of this code on my jeep.
I ended up dropping the pan again, replaced both transmission filters, and both speed sensors, put it all back together and filled it up with about 8 quarts of ATF+4 since the old transmission fluid smelled really burnt. and now it's running with no problems!
link375 is offline
post #34 of 34 Old 12-18-2013, 12:28 PM Thread Starter
99WJLimited
Sorry for the long delay. Yes it seemed to have fixed it and I have had no issues since then!
99 Grand Cherokee Limited 4.7 45RFE Quadra-Trac II Dana 30 Dana 35 Firestone Destination A/T 245/70R/16
“If I had no sense of humor, I would long ago have committed suicide.” ― Mahatma Gandhi
99WJLimited is offline
