Main Bearing/Connecting Rod Torque Specs-4.0 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Main Bearing/Connecting Rod Torque Specs-4.0
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 07-07-2011, 01:16 PM   #1
bannas12
Wj Main Bearing/Connecting Rod Torque Specs-4.0
I have been searching the forums and net for the Main Bearing Torque Specs on a 2000 Grand Cherokee 4.0.
What I have found was 33lbs but the motor will not turn over even with using a 3ft cheater pipe. ( I think that is too tight, Tried setting 3 times now)
I just de-glazed the cylinder walls because I had 1 cracked piston skirt and 2 cracked pistons(This is common from what I have read). I am putting a new oil pump in as well. Cylinder walls were fine, I used the 3 stones to de-glaze(some refer it to honing but it's not). I'm Using the old bearings and crank, they are fine with no visual damage.
The 4.7L states 15lbs torque and then a 90 degree turn.
Here is the website for the torque on the 4.0L;
http://jeephorizons.com/tech/99_40l_torque_specs.html
Here is the for 4.7;
Jeep 1999 4.7L Engine Torque Specifications
http://jeephorizons.com/tech/99_47l_torque_specs.html
99-04 should be the same, Info on this would be much appreciated!
bannas12 is offline   Reply With Quote
Unread 07-07-2011, 01:39 PM   #2
twinsdaddy
80 on the mains, 33 on the rods. Just built mine and it should spin over easily with a 12-18" breaker bar.
Did you put the thrust bearing in the right journal? What were your plasti-gauge measurements?
twinsdaddy is offline   Reply With Quote
Unread 07-07-2011, 03:01 PM   #3
bannas12
I didn't remove the crank, I am using the same one. I will check the measurements for the rod bearings tonight with the plasti-gauage.
The only thing I can thing of is the they are in reverse order. I labeled the bearings as I removed them to make certain they went back onto the same position they came out.
Unread 07-08-2011, 06:51 AM   #4
twinsdaddy
possible that maybe you have the rod caps on backwards too? Got me stumped...
Unread 07-08-2011, 07:06 AM   #5
tsconver
2003 WJ
the two motors are very different. I know most of the bolts on the 4.7 are torque to yield and you replace them everytime you pull it apart. That is what the add 90 degrees to the bolt after you reach torque means.
If you added any additional turn after reaching torque on the 4.0 you will be way over torqued on the 4.0, rod bolts should be 33 ft lbs.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
My Build Thread
A few goodies
http://s257.photobucket.com/albums/h...umb55839/jeep/
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
http://www.zrxoa.org/
2006 Red Liberty
Wife's ride, pretty stock
http://i257.photobucket.com/albums/h...mage0008-1.jpg
http://www.cnc4x4.org/
http://www.treadlightly.org/
tsconver is offline   Reply With Quote
Unread 07-11-2011, 07:04 AM   #6
bannas12
thanks for the help guys, turned out I had a couple of the rod caps backwards.
Unread 07-11-2011, 07:32 AM   #7
twinsdaddy
Glad you figured it out!
Unread 08-20-2011, 10:35 AM   #8
remone23
good day am trying to fine the torque lb for a 2006 grand cherokee connecting rod bearing
remone23 is offline   Reply With Quote
Unread 08-22-2011, 08:55 AM   #9
bannas12
I wasn't able to pull anything quickly up, but if the 2007 engine is the same here is some info I found on a 3.7L
http://imageshack.us/f/156/jeep37.png/
looks like 27N.m/20Ft LBS.
Here is the post I found the info in;
http://www.jeepforum.com/forum/f67/0...specs-1166356/
good luck!
