MAF sensor - JeepForum.com
post #1 of 8 Old 08-06-2010, 03:50 PM Thread Starter
SWDoodle
MAF sensor
Question is "where is it at"? Do they even have one on the 4.0L's? I am suffering from poor mileage and figured I'd start with the basics. Changed plugs, cleaned filter, etc. I know that they recommend cleaning the MAF sensor but I can't seem to find it on the Jeep. Any suggestions? Only thing I've come across is the Idle air control valve.
SWDoodle is offline
post #2 of 8 Old 08-09-2010, 04:51 AM
freakinheep89
there is no MAF on any jeep, except maybe the new motors(3.7/5.7 hemi) im not sure about them. but on any jeep 05 and down there are no MAF sensors. if your getting crappy mileage, welcome to Jeeps. best thing to do is to check for codes, see if one of your O2 sensors is acting up or something.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #3 of 8 Old 08-09-2010, 08:18 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
No, but there is a MAP sensor, TPS sensor.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #4 of 8 Old 08-09-2010, 12:29 PM
sdavisbone
and IAC valve.... that's what is usually recommended to clean. They are all on the throttle body.
sdavisbone is offline
post #5 of 8 Old 08-09-2010, 03:43 PM
jclaudii
Is your check engine light on? If so with vehicle off and turn key to run position and then off three times in a row ending in the run position and watch your odometer for the codes stored. a bad O2 sensor will make it run extremelly rich and get around 5.2 miles per gallon!
jclaudii is offline
post #6 of 8 Old 08-11-2010, 03:17 PM Thread Starter
SWDoodle
How do you clean the IAC valve? Can you clean it with the MAF sensor cleaner? Where exactally is it located on the 4.0L?
SWDoodle is offline
post #7 of 8 Old 08-11-2010, 03:31 PM
sdavisbone
It's on the back of the throttle body. Not positive, but I bet you have a MAP sensor, instead of MAF.... pressure rather than flow. Map is on drivers side of throttle body.
Search terms IAC and clean. Someone did a great write up with pics. That should help.
post #8 of 8 Old 08-11-2010, 04:12 PM
freakinheep89
yes there is a MAP sensor on it, on the throttle body like ^ said. if you want better mileage i would change more than just the plugs, go ahead and replace the coil, and the plug wires, also the dist cap and rotor. its a good investment
TJ-
hogh voltage 02 sensor/bad cool sensor Jh24k ZJ Grand Cherokee Forum 0 01-24-2010 11:33 AM
Sensor Reads Throttle/Pedal Position Sensor/Switch A Circuit Low Input Vincent2for2 ZJ Grand Cherokee Forum 3 11-01-2009 01:01 AM
Bank 1 Sensor 2 '01 Grd Cher o2 sensor location mgrean ZJ Grand Cherokee Forum 15 02-06-2009 01:41 PM
solar sensor and in vehicle temp sensor Bekim ZJ Grand Cherokee Forum 10 10-08-2007 10:04 AM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 04:52 PM
