lowest profile - JeepForum.com
post #1 of 11 Old 05-15-2013, 02:27 PM Thread Starter
HARRISON111
Wj lowest profile
Hi all,
Im currently running 235/65/17 on my 2.7 CRD has anyone got any thoughts on fitting lower profiles? say 50s.
HARRISON111 is offline
post #2 of 11 Old 05-15-2013, 02:37 PM
4Tom
Yes don't do it ha ha
It will look horrible on stock rims
if you bought bigger rims then lower profile tires would look better and make more sense
Ive 245/65R17 ATs fit nicely
WJ 2001 3.1TD
Tom
4Tom is offline
post #3 of 11 Old 05-15-2013, 02:40 PM Thread Starter
HARRISON111
YEA I know what you mean just thought lower profiles would make it handle a little better.
post #4 of 11 Old 05-15-2013, 02:45 PM
alfaitalia
They will but a set of Billys and a stronger anti roll bar will do a better job. I run my Grabbers at 42 psi on the road and that eliminated some of the side wall flex you might be feeling. Also I run the extra load version of the tyre which has stiffer sidewalls.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #5 of 11 Old 05-15-2013, 02:50 PM Thread Starter
HARRISON111
Thanks Alf but what are Billys?
post #6 of 11 Old 05-15-2013, 02:59 PM
4Tom
Going from 235 to 245 wide will give you more grip. If you are just interested in road use only a stiffer rear sway bar will make it handle better.
WJ 2001 3.1TD
Tom
4Tom is offline
post #7 of 11 Old 05-15-2013, 03:13 PM
Jeeples
Jeeples's Avatar
Bilstein shocks.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is online now
post #8 of 11 Old 05-15-2013, 03:52 PM
Thomahawk
I had 20's 50 profile tires (255/50/20) on my Jeep, it sure did handle like a sportscar,,,
I dont have Those anymore, for several reasons, and i dont miss them,
With stiffer springs, better shocks, upgraded swaybars, and Good 70 profile tires, it will handle about the same.
Buildthread
Thomahawk is offline
post #9 of 11 Old 05-16-2013, 09:56 AM Thread Starter
HARRISON111
Thanks for your thoughts guys Im looking to try cheaper options first, So far air up to 36 psi 0.50 and does feel a little better they only 30 PSI.
post #10 of 11 Old 05-21-2013, 07:32 AM
sprocket1200
If the shocks have never been replaced that will make a huge diffence. Sway bar was awesome too!
sprocket1200 is offline
post #11 of 11 Old 05-22-2013, 03:21 PM Thread Starter
HARRISON111
Thanks for that sprocket
