low oil pressure - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > low oil pressure
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 03-21-2012, 12:53 PM   #16
jerrod710
2003 WJ
Look into the oil pump and tube before throwing terms out like "new engine." Start small in diagnosis.
jerrod710 is offline   Reply With Quote
Unread 03-21-2012, 03:29 PM   #17
WJMay
Originally Posted by billzcat1
Ruh-roh!
You can switch to a thicker oil but it is only a band-aid, trading flow for pressure. It's a ticking time bomb with pressure that low.
Well I changed to oil to 5w-30 and it's normal for now. Do you think my oil pressure was low because I used 10w-30 instead of 5w-30? Cause I was reading that you have to use 5w-30 on the 4.7
WJMay is offline   Reply With Quote
Unread 03-21-2012, 03:35 PM   #18
billzcat1
Chicken in a Turkey Suit
2003 WJ
It shouldn't make that much difference, in fact most 10W-30s are slightly thicker at operating temp than 5W-30. This would give higher oil pressure than the thinner oil. Is it possible you were just low on oil and starving the pickup?
billzcat1 is offline   Reply With Quote
Unread 03-21-2012, 04:03 PM   #19
chrism1367
2003 WJ
it shouldn't make that much difference, in fact most 10w-30s are slightly thicker at operating temp than 5w-30. This would give higher oil pressure than the thinner oil. Is it possible you were just low on oil and starving the pickup?
x2
chrism1367 is offline   Reply With Quote
Unread 03-21-2012, 04:10 PM   #20
WJMay
Hmmmm.... That might explain why there wasn't that much oil when I changed it. Wouldn't the oil light be on though if it was low on oil
Unread 03-22-2012, 07:20 AM   #21
slick1474
Not to sound funny but you changed the engine 8 months ago and your not checking the oil level so much so that when you do an oil change not much comes out..... give the new motor a chance and check the dipstick level occasionally and top it up!!
slick1474 is offline   Reply With Quote
Unread 03-22-2012, 08:53 AM   #22
KayCeeJeep
Yes, keep an eye on your oil level. As stated above the 10w30 should have created slightly higher pressures, not less, but it sounds like you were really low that certainly could have been the problem. Don't do that again no matter what you have in it.
KayCeeJeep is offline   Reply With Quote
Unread 03-22-2012, 03:12 PM   #23
billzcat1
2003 WJ
The oil pressure warning is not an oil level sensor. At least you noticed that you had low oil pressure, but it seems like you are on the way to buying yourself another engine. Start paying attention to your Jeep!
