low battery voltage - JeepForum.com
post #1 of 8 Old 02-06-2014, 05:39 AM Thread Starter
georged
low battery voltage
The battery in my 04 GCL 4L goes low (12.3 V) after few days of not driving. With temperature above 70 and driving the battery voltage does not go above 13.7. Is there a way to get it to go over 14?
Also I believe I read there is a way to bypass the BCM and use an external alternator - any comments?
georged is offline
post #2 of 8 Old 02-06-2014, 06:22 AM
bessyboy
Just get a bigger alternator. Mine runs right around 13.8-.9 with the stock one which is plenty
-2001 WJ Limited, 4.7L V8, Thrush Glasspack muffler dumped before axle(no tailpipe), Spectra CAI,
Rusty's 2" BB
bessyboy is offline
post #3 of 8 Old 02-07-2014, 03:57 AM
86cj74.2L
86cj74.2L's Avatar
Is your voltage still 13.7 at idle with everything on? AC on high, all lights, rear defroster?
86cj74.2L is offline
post #4 of 8 Old 02-07-2014, 04:46 AM Thread Starter
georged
Voltage stays there unless the temperature is lower than 50. Battery is new and tests better than rated.
georged is offline
post #5 of 8 Old 02-07-2014, 05:39 AM
Matrixxxx
2005 WK
i would check your voltage with a multi meter, the meters are not usually very accurate. its your voltage regulator which determines the voltage, the alternator will go to high volts when charging as the battery charge increases the voltage will get lower.
Matrixxxx is offline
post #6 of 8 Old 02-07-2014, 06:10 AM
bessyboy
What exactly should the output be? I'm sorta curious now, I put a multimeter across the battery and before starting it read 12.23 and after starting it was 13.8. I also put this other tester on I'm pretty sure it was for amps and it read right on the boarder of "OK". What is the amps supposed to be I will be testing it later
Rusty's 2" BB
bessyboy is offline
post #7 of 8 Old 02-07-2014, 09:58 AM
rep-tile
Cash 4 Clunkers Survivor
rep-tile's Avatar
Anything 13.5-14V is normal. The output voltage is controlled by the PCM. Your battery voltage does sound low. How do your battery connectors look?
rep-tile is offline
post #8 of 8 Old 02-07-2014, 10:45 AM
86cj74.2L
86cj74.2L's Avatar
If you in this range at the battery with all accessorys but the rear defrost on I'd say your ok.
