Low Air Flow passenger vents - JeepForum.com
post #1 of 6 Old 08-31-2011, 11:09 AM Thread Starter
Okiesteve
Wj Low Air Flow passenger vents
I know this has been hashed, just can't find the correct link to my problem...2002 GC Limited, auto hivac. Low air flow from passenger upper vents. I know the Recirc Door is not working, I have a fix for that coming, but either in full open or closed position, I get very low air flow from the passenger vents (all 3)....Hivac has error code 52. Airflow at lower vents is fine, defrost seems to be good, just the passenger side air vents.
Thanks Okie Steve
Okiesteve is offline
post #2 of 6 Old 08-31-2011, 11:35 AM
tjlmbklr
Thanks Okie Steve
If I recall, I thought 52 was a blend door code.
Bone Stock 2002 Grand Cherokee Limited
4.7L HO, Changed Stock NV247 Quadra-Drive T-case to a 242 Selec-Trac Shifter and all.
Upgraded my rims to 5 Spoke Rogue from '11 Grand Cherokee
tjlmbklr is offline
post #3 of 6 Old 08-31-2011, 12:01 PM Thread Starter
Okiesteve
From Blendorstore.com: The two common symptoms are: You feel a draft coming from under the dashboard on the passenger side when the vehicle is moving. The other symptom is, you have the fan turned on HI and there is little or no air blowing thru any vents!
There are two ways to check for a recirculation door failure if you have the Grand Cherokee with the Automatic Zone Control system (AZC). The first is you can read the fault codes of the AZC system.
To read the AZC fault codes: See above description
19 or 51 – AI (Recirc) door travel range too small
20 or 52 – AI (Recirc) door travel range too large
The above codes indicate a recirculation door problem. #52 is the most common.
The problem is that the system(s) for a code 52, is low air flow on ALL vents....I am ONLY having problems with the Passenger side. That is what the problem is. Just fine from driver side vents, very low (with fan on full) on passenger side.....steve
post #4 of 6 Old 12-13-2012, 04:19 PM
01jeepGCL
Did you ever find the solution to this problem? My Jeep is doing the same thing.
01jeepGCL is offline
post #5 of 6 Old 01-18-2013, 03:57 PM
maloj2003wj
2006 WK
I have the same issue probably gonna try to pull the glove box out and access the recirc door to see whats going on. I know that recirc option in my car does not work at all. the light comes on but the motor does not. so if i had to guess the door may be sitting on the motor. But thing that bothers me the most is the fact that i get cold air from outside blown in. it does not do it all the time but most of the time. i was also considering on getting a replacement that mopar makes.
2006 WK LIMITED|5.7 HEMI
maloj2003wj is offline
post #6 of 6 Old 01-18-2013, 09:09 PM
highlander03
Me too!
Hey I'm new to this forum!
Please make sure ya post the fix my 2002 grand limited has the cold air problem on the passenger side but not a constant thing just from time to time or on road trips! Love to to know the fix! On a side note about to do what I call process improvements on my ride ( haven't decided on a name yet) starting with a lift and tires!
Man you guys rock out here going to drive me broke with ya sick rides!
highlander03 is offline
center vents blow about 10 degrees warmer than pass vents. likely not blend doors jclaudii WJ Grand Cherokee Forum 0 06-24-2011 09:46 AM
Blend Door Fixed but still low air flow sbernsto WJ Grand Cherokee Forum 4 12-24-2010 06:17 PM
O2 sensor question with high flow cat DaveRous WJ Grand Cherokee Forum 2 10-14-2010 07:02 PM
High flow WJ exaust on the cheap centralmuscle WJ Grand Cherokee Forum 6 09-29-2010 08:47 PM
Air Flow switches under acceleration???? XxWickedz28xX WJ Grand Cherokee Forum 3 05-15-2010 12:08 AM
