Loss of power under acceleration. :( - JeepForum.com
post #1 of 108 Old 10-25-2010, 12:45 PM Thread Starter
SplitNail
When I give it gas sometimes the jeep will not go. It will just fall on it's face and idle. It's okay for a few seconds and then it's fine. I can floor it and have no problems either. It's like there are air bubbles in the in the fuel lines. I replaced the fuel filter about 2 months ago with a molar filter. That helped but still cuts in and out sometimes. Any guesses?
Here is a video of the sound of my fuel pump.... Its odd.
http://www.youtube.com/watch?v=R2Mztris62I
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #2 of 108 Old 10-25-2010, 01:04 PM
narnwv
narnwv's Avatar
"This video is unavailable"
~Aaron
narnwv is offline
post #3 of 108 Old 10-25-2010, 01:14 PM Thread Starter
SplitNail
I know it's still processing. /:
post #4 of 108 Old 10-25-2010, 01:16 PM
narnwv
narnwv's Avatar
I guess i spend too much time on JF :-)
~Aaron
narnwv is offline
post #5 of 108 Old 10-25-2010, 01:48 PM Thread Starter
SplitNail
I would think it would be done by now... It's only 6 seconds long...
post #6 of 108 Old 10-25-2010, 01:49 PM
narnwv
narnwv's Avatar
Didn't you have fuel filter issues a little while back? Could that be related?
~Aaron
narnwv is offline
post #7 of 108 Old 10-25-2010, 05:30 PM Thread Starter
SplitNail
nope.... negative cable was corroded......... so stupid..... oh well its fixed.
post #8 of 108 Old 10-25-2010, 05:43 PM
801DubJay
Do you ever have hesitation problems like this during a certain RPM range? I had something very similar starting about 3200 rpms... it felt like the fuel just cut out all of a sudden.
'00 WJ Laredo V8 aka Katie
My Build Thread: http://www.jeepforum.com/forum/f197/801dubjay-build-thread-1114628/
801DubJay is offline
post #9 of 108 Old 10-25-2010, 05:45 PM Thread Starter
SplitNail
YES!!! I do!! I dont know what it is! it drives me CARZY!!
post #10 of 108 Old 10-25-2010, 05:57 PM
801DubJay
Well if you figure it out, tell me!! hahaha... I have had the saaaaame problem, but only when I've added fuel injector cleaner. WTF?? And bcz it's so inconsistent, I haven't been able to properly diagnose it. I don't throw ECU codes & I've checked my evap system as well as fuel filter... and found nothing!! Maybe it's ignition retard from knocking?? I dunno, man
post #11 of 108 Old 10-25-2010, 05:59 PM Thread Starter
SplitNail
I dont know either. How long have you had it? The video at the top works now.
post #12 of 108 Old 10-25-2010, 06:10 PM
801DubJay
Yeah, that doesn't sound right... should be a solid hum sound. I would check the fuel pump & all seals that go with it... this may sound crazy, but have you ever had a problem starting up? Like it will turn & turn & then finally it starts?
I've only had the hesitation problem when I've used fuel injector cleaner either that or it was just HIGHLY coincidental!
post #13 of 108 Old 10-25-2010, 06:12 PM Thread Starter
SplitNail
Oh mine hesitates... I hate it. I dont know what it is... Ill have to check for leaks.
post #14 of 108 Old 10-25-2010, 06:19 PM
801DubJay
Sucks man... Good luck! If mine does it again & I can figure it out, I'll for sure let you know!
post #15 of 108 Old 10-25-2010, 08:11 PM Thread Starter
SplitNail
Well that didnt fix the jeep. Its sputtering really bad. But when I floor it its fine... Any ideas?
2004 Jeep Grand Cherokee Overland 4.7L HO Loss of Performance / Acceleration Problem DHewes WJ Grand Cherokee Forum 70 03-30-2017 08:51 PM
Loss of power @ low revs Mr_Grumpy WJ Grand Cherokee Forum 6 09-30-2010 03:06 PM
Loss of power steering at idle? RNCC4X4 WJ Grand Cherokee Forum 4 08-31-2010 08:49 PM
Random no start with total power loss dougy147 WJ Grand Cherokee Forum 2 07-27-2010 06:04 PM
2000 4.7 V8 Laredo power loss XSNRGY WJ Grand Cherokee Forum 6 04-10-2010 02:33 AM
