Loss of power and steering wheel wobble in wj - JeepForum.com
post #1 of 3 Old 01-24-2014, 07:53 AM Thread Starter
zperkins12
I had a loss of power and steering wheel shaking also with loud noises from engine. Any opinions on what could be wrong with it? It's a 2004 wj. It's was also in 10 degree weather.
zperkins12 is offline
post #2 of 3 Old 01-24-2014, 08:05 AM
Jeeples
Jeeples's Avatar
Your symptoms sounds just like what it does when it's not doing what it should because of how it is.
Could you maybe provide a little more info on what's going on? Start by pulling the OBDII codes (even if your CEL isn't on), this can be done by turning the ignition on-off three times (do not start the engine) and leaving it in on the position. The odometer will display any codes stored, and will show 'done' when all codes have been displayed.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #3 of 3 Old 01-24-2014, 08:14 AM
ChrisHager
Administrator
ChrisHager's Avatar
Hahaha... Mine!
Also, I agree - check for codes first of all. Also, did the power loss happen when initially started? After it warmed up? The entire time you were driving? Did this start out of nowhere or did something happen previously that may help us figure out what's going on? The more you help us, the more we can help you.
Just off what you say, the loss of power instantly triggered in my mind an issue with your catalytic convertor or O2 sensors but that's just a guess without more information.
Steering wheel shake - does it shake all the time, when hitting bumps, at certain speeds, etc.?
Oh, and what vehicle do you have (year/trim/engine/trans/transfercase/etc.)? Filling out your profile will be helpful.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
