looking at a 2004 Limited . . . - JeepForum.com
post #1 of 14 Old 01-26-2009, 05:25 PM Thread Starter
PetesPonies
I was wondering what to watch for and what are the known long term problems? Thanks
PetesPonies is offline
post #2 of 14 Old 01-26-2009, 05:33 PM
allenjp
Do a search on the blend door issue. All the limiteds have them. Other than that they are pretty well rock solid. Is it a 4.7L with quadra drive?
This is my JEEP. There are many like it but this one is mine...
1996 ZJ 318 Laredo Quadra Trac -SOLD (I'm gonna miss her!)
2002 WJ 4.7 Limited Quadra Drive (sharing it with wifey for now...)
allenjp is offline
post #3 of 14 Old 01-26-2009, 05:46 PM Thread Starter
PetesPonies
Yes Quadradrive. Does that work well? It seems I can't get away from blend door problems I have been through this on Lincolns I have owned. I have fixed them, buts its a real PITA.
post #4 of 14 Old 01-26-2009, 05:53 PM
allenjp
There's loads of info on it here on this site and on others. I bought mine in spite of that just realising that I'll have to do it one day. To me it's worth it.
I haven't had a chance to test my qudra drive out yet but it is supposed to be the best on snow/ice/mud...the BEST. It can transfer torque not only from rear to front but also side to side and it can transfer 100% of engine torque to any one wheel. The real cool part about it is that it has the Varilok LSD'd both front and rear. Pretty cool setup. Some of the traditionalists still prefer the two driveshafts to be locked when they need the 4WD though...
Only thing to be aware of is that the diffs and transfer case require special fluids that only come from the dealer and they are EXPENSIVE (about $250 for everything) and they have to be serviced often
allenjp is offline
post #5 of 14 Old 01-26-2009, 06:45 PM
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
The downside to quadra drive is its complex and can be expensive to maintain. But when it maintained and operating correctly it performs very well.
Personally I prefer the simplicity of the Selec Trac system (242) and if I were to buy another WJ in V8 form I would hunt for the elusive V8 242 combo.
Like mentioned before blend door maybe an issue. This WJ has updated brakes because its a 2004 which is good. (warping was a common issue on early models) but I still feel the WJ's weak point is its brakes. They may still warp despite updated calipers, but the interval between warpage will likely be much more reasonable especially if you go easy on them.
WALTER
walter_da_jpr is offline
post #6 of 14 Old 01-26-2009, 08:04 PM Thread Starter
PetesPonies
Yeah . we have a Cherokee now. I do like the simplicity of that vehicle. That is primarily why I am asking about this Grand Cherokee. My wife wants a newer vehicle and a few luxury items such as leather, heated seats , sunroof etc. So . . Im looking around
post #7 of 14 Old 01-28-2009, 04:35 PM
JG_Canuck
Heated leather seats and Quadradrive, the pinnacle of a luxury and performance DD if you live anywhere there is snow.
The blend doors aren't a complicated fix, just a PITA as noted. Some have used the Heater treater with good success, but depending on what (if anything) is broken you may have to pull out the instrument panel anyway. You never know, you may come across one that's already been fixed. Just pull the HVAC codes on any ones you test.
Canadian Jeep Club Member Forty-Two
JG_Canuck is offline
post #8 of 14 Old 01-28-2009, 05:31 PM
windsors03cobra
Test the heated seat they seem problematic in this brand automobile.
windsors03cobra is offline
post #9 of 14 Old 01-28-2009, 08:46 PM
kentman
kentman's Avatar
2006 XK Commander
I use Mobil 1 75W140 with the Mopar brand friction modifier. The Mobil 1 is about $18 per quart, and you need about four of those. The friction modifier is like $12 per bottle, and you need two of those. That is $94 for both differentials. I do use the Mopar brand transfer case fluid. That is like $15 per quart, and you need two of those. That is another $30.
That makes a total of about $125. If you wanted, you could substitute non-synthetic 75W140 gear oil in place of the Mobil 1, and that would be adequate. That would get you down below $100 for both differentials and the transfer case. Fluids costs are higher, but not that bad.
On the XK, I use 7 quarts of 5W20 Mobil 1 every 5K miles. That is about $60 of oil every oil change. I also have to replace 16 platinum spark plugs every 60K miles. It also has the limited slip diffs and requires the Mopar transfer case fluid. The XK seems much more costly to keep it up, but I would not want anything else.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #10 of 14 Old 01-29-2009, 10:21 AM
allenjp
16 Spark plugs???
allenjp is offline
post #11 of 14 Old 01-29-2009, 10:32 AM
JG_Canuck
The Hemi has 2 per cylinder.
post #12 of 14 Old 01-29-2009, 11:19 AM
allenjp
Of course I knew that! I was just testing you...
allenjp is offline
post #13 of 14 Old 01-31-2009, 01:39 PM
04-ID-Overland
Try for a Overland, it gives you a few things that the already loaded up Limited does not. Rock rails, wood grain steering wheel, different leather seats with nice stitching, and of course the Overland Badge
2004 JGC, Overland, Black Exterior, Two Tone Black/Gray Leather Int, Navigation, QuadraDrive, 6" Suspension Lift, 20" Incubus Wheels with 285/50/20 Toyo Open Country A/T's, ONLY 20K Miles!
1998 Toyota 4Runner Limited, White/Pewter Exterior, Tan Leather Interior, 4x4, Rear Locker, 20" Akuza Wheels with 285/50/20 Toyo Open Country A/T's.
04-ID-Overland is offline
post #14 of 14 Old 01-31-2009, 02:10 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Those rock rails won't hold up offroad very well. Maybe a bump but that is about it.
Brian
WJ, WK, CJ5
GraKee99 is offline
2004 GC Limited - How Scr###d? Gander2 ZJ Grand Cherokee Forum 9 01-17-2008 07:43 AM
Looking at a 2004 Limited JGriff99xj ZJ Grand Cherokee Forum 24 01-15-2008 10:07 AM
2004 GC limited - need input please!! aar1 ZJ Grand Cherokee Forum 1 10-25-2007 07:02 AM
2004 Limited headliner air bag bob snyder ZJ Grand Cherokee Forum 1 09-08-2007 09:04 AM
Where to buy front grill for 2004 Limited? bkeast17 ZJ Grand Cherokee Forum 0 09-21-2004 10:45 AM
