-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   long crank after fill-up (http://www.jeepforum.com/forum/f310/long-crank-after-fill-up-1676529/)
kc2mrg 10-12-2013 10:51 AM
ok, maybe someone can shed some light on this issue, because im kind of at a loss...
ok, i have a 2004 4.0 with about 168k on the clock, ive replaced the fuel filter with OEM MOPAR around 140k, and everything has been great, but now, every time i go and fill up with fuel, when i get back in the jeep, it cranks like i have no fuel pressure what so ever, about a 10sec crank time, but only happens after i fill it up.
ive tried filling up and then waiting like 15 minutes, and still will do the same thing, but after that one long crank, it will start instantly like normal, until i fill it up again
yes i do fill up after it is warmed, but have ruled out fuel soak on the injector, because after the long crank it wont do it, and it also will do it while the jeep is still warming up
so im at a loss... it never leaves me stranded but is very annoying
BlueJc 10-12-2013 11:27 AM
Try this....
Open your petrol cap then try and start it up. See if you get the same symptoms with the petrol cap off.
when you go to fill up do you notice a hiss or a pop when removing your petrol cap like there's a difference in pressure like a vacuum in the tank?
I'm working on a theory.... does the negative pressure in the fuel tank help the check valve in the fuel pump?
kc2mrg 10-12-2013 08:25 PM
i dont know, lol, i dont think i get a hiss or a pop ... ill try this next time i have money to put more gas in the jeep, also if it helps, it has P0455 major evap leak, but this code has been in the jeep for 2 years, this issue just started in the last cpl months
Mav-Jason 10-12-2013 08:34 PM
Wow that is a strange one. Shot in the dark here, and I haven't done mine yet, but I assume the filter is directional. Possibly backwards? Not sure why that wouldn't change anything for 28k up until now, but maybe worth a shot to look at.
kc2mrg 10-12-2013 08:49 PM
no, the fuel filter also has the pressure regulator built into it and has 3 lines coming out of it 2 one side and 1 the other and each line has a different style connector to prevent a mix-up while hooking it up, basically stupid proof lol
Big_Wall 10-15-2013 11:44 AM
My wife had a VW Passat with this same problem with the major evap leak code also. Our mechanic spent 6 hrs tracking down the leak and finally found and fixed it. It solved the problem. He didn't charge us for his time. I think it pissed him off and he wanted to find the problem.
kc2mrg 10-16-2013 08:13 PM
haha, yea im a BMW tech and i know what that feels like, but what ended up being the issue?? might lead me in a direction to follow
Big_Wall 10-16-2013 10:21 PM
My wife picked her car up and didn't ask where he found it. I was just happy to have it fixed. I hated that car.
kc2mrg 04-20-2014 11:05 AM
ok, well to continue my saga, one day a few months ago the jeep quit doing the long crank thing after fill-up, cool it fixed itself, wrong, well, about a week ago, i finally got modivation to try and fix my major evap P0455 code. i smoked it, found the evap hose from the canister to the purge solenoid was broken, easy, replaced hose, cleared light and went to fill it up, and BAM! long crank, so, great, my problem is back!
i started by replacing the vacuum vent valve back at the charcoal canister, and still had a long crank and still threw the 0455 code still long crank right after fill-up but no smoke anywhere.
found out that purge solenoid (one under the hood) is normally closed, so removed it and could blow threw it, meaning its shot, went to NAPA got a new one for like $35-40 and installed, cleared light and went and filled it up .. no more long crank after fill-up and fixed my check engine light!
so, if your jeep is throwing a P0455 code and it long cranks upon the first start-up after filling the tank, check your purge solenoid, make sure its staying closed with the car off (blow through it or vacuum gauge) if it is open, replace it and check, fixed mine!
TeXJas 04-20-2014 11:12 AM
Had the same problem until I replaced my dcp valve last week.
kc2mrg 04-20-2014 11:29 AM
Dcp valve?
TeXJas 04-20-2014 11:46 AM
Duty cycle purge solenoid
kc2mrg 04-21-2014 05:14 PM
Ah I knew that ... lol
The time now is 11:46 PM.
